Backhoe Will clay soil plug up a 9" backhoe bucket?
   / Will clay soil plug up a 9" backhoe bucket? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a JD 790 with JD7 backhoe and mostly use a 17 inch bucket that works great. I would like to get a 9" bucket to use digging around trees before transplant and for pipes and wires but was told this size bucket would plug with my clay soil because it is too narrow.
Since I would dig mostly in dry conditions--but midwest clay--I wonder if anyone has any experience regarding this 9" bucket issue?
Any advice appreciated.
   / Will clay soil plug up a 9" backhoe bucket? #2
I have a Woods BH on my L3400 with a 9" bucket. I have a sandy clay soil here in MS and have never had a problem even when the stuff was saturated with water. If its wet it will come out as one solid piece sometimes though. I told my wife that we ought to fire one and sell it at the flea market ;) I have a 24" bucket also and I seem to do more stuff with the 9". I almost never attach the bigger bucket unless I have a big hole to dig.
   / Will clay soil plug up a 9" backhoe bucket? #3
no 9" exp, but my 12" clogs up fast if I dig most clay.
It goes, scoop with BH, shovel out bucket , scoop with bh, shovel out bucket....makes for a long day.
jb
   / Will clay soil plug up a 9" backhoe bucket? #4
If I had a picture, I'd post it, but no such luck. The general contractor I work for has several back hoes. Even the bigger buckets (24", 30") will pack full of wet clay mud at times. We weld a short length of 3/8" chain, about 16" to 18", in the inside of the bucket, in the deepest part of the bucket. It works!
   / Will clay soil plug up a 9" backhoe bucket? #5
Anything smaller than 12" tends to plug up easily. I have a 6" bucket, (with chain, and air hole, and dual taper design, and tried spraying it with various things from silicone to Pam), and it is useless in clay soil.
   / Will clay soil plug up a 9" backhoe bucket? #6
I have a 9" that I have dug clay with .... how well it works all depends on the moisture content of the clay -- too dry or too wet and it just doesn't.....Even when it's right you still have to develop a technique for getting it out. I found that back dragging the bucket (reverse curl) gets it out fairly well...and tapping it on the ground sometimes helps too. Digging clay is just no fun regardless of bucket size. But it beats doing it by hand.
   / Will clay soil plug up a 9" backhoe bucket? #7
I have a BH90 on my Kubota 3830 and bought a 12" bucket to install 4" Drain Tile... I also have a 24" that came with the hoe. After I installed the tile I have never put the 12" back on... I live in Southern Indiana and we have allot of clay... it worked well for the job it was intended for however, I did spend allot of time shaking the bucket and this was in failry dry conditions...
Just my $0.02
Good luck..
Kevin
   / Will clay soil plug up a 9" backhoe bucket? #8
Very good, real world advice. Adhesion has to be your friend,try not to mash full bucket/w/heaping load hard against hole/ditch,(seems like the harder you mash against the stuff the better it sticks) try to use cut action-rather than normal dig action.;) After diging the stuff,I wondered if God made the stuff as a joke of some sort? It's a mess to fool with. :) Also a bigger bucket will increase digging force/stress on undercarrage frame/tractor. Don't damage your tractor.
I keep waiting for someone to build Ice-cream-scoop proto-type and post pic's on TBN?
We weld a short length of 3/8" chain, about 16" to 18", in the inside of the bucket, in the deepest part of the bucket. It works![/QUOTE] GOOD IDEA Farmwithjunk.
   / Will clay soil plug up a 9" backhoe bucket? #9
Our clay sits atop hardpan on flat ground. It can get so wet and soupy that it won't adhere. Totally dry does not adhere, but most anything between totally dry and hypersaturated sticks better than most any mortar available.
That makes a lot of sense.
Too bad teflon gets abraided off so easily.
I think part of the reason the stuff sticks so well is that a vacuum forms at the bottom of the bucket. Air can't get into the space between the clay and the metal. Too bad there isn't a way to have a high pressure air line going to the center of the bucket such that a big shot of air injected there would eject the material. A hose to the back of the bucket would not work 'cause it would get knocked apart while digging. The only thing I can envision would be to cast the steel bucket with an internal channel, much the way an intake manifold is cast for an engine. The high pressure air could be forced through that to the bottom inside of the bucket. Obviously this system would be so expensive that it would only make sense to use it in conjunction with a high grade commercial tractor that is in use all the time.
   / Will clay soil plug up a 9" backhoe bucket? #10
My BH has a 10" bucket. Lots of different soils around where I live and I am on the lake so the moisture content varies a lot depending where you are digging. Some places I can dig quite a bit without ever getting off the tractor to clean the bucket, other places I am on and off steady. My best digging experience was digging a trench for a drain tile for my neighbour. He stood off to the side, if the bucket emptied, great, if it didn't he would poke the dirt out with a small spade.
The BH is a great tool, sure beats digging by hand but, if the dirt is sticking in the bucket it sure makes for a long day. Having a helper with a spade that fits in the bucket is the best solution I have found so far. I'm intrigued with the compressed air idea though...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
1999 UTILITY 102" X 53' REFER TRAILER (A51243)
1999 UTILITY 102"...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
ECHO SRM-2120 GAS POWERED WEED EATER (A51244)
ECHO SRM-2120 GAS...
