Will a X series deck fit a 400 series?
   / Will a X series deck fit a 400 series? #1
Jason B
Bronze Member
Ontario Canada
John Deere 425( soon to be 455)
Hi
I was wondering if a "54" deck from the X series, will fit a 425? If so, is there any modifications needed for it to fit or are they not compatable? Take Care Jason B
   / Will a X series deck fit a 400 series? #2
I am assuming you have a 54" mower deck. The 54 and the 54C decks are similar, but the gearbox is in a different position. I have not physically attempted to put a 54 deck under an X series or vice versa, but I do not believe it will work without modifications.
   / Will a X series deck fit a 400 series? #3
Apparently, the mount is completely different. I have a chart for accessories covering all of the 400 and X series through 2004. It shows products originally sold for each model and which newer attachments will fit older machines. It shows no crossover in the mowing decks between the X series and the 400 series. The decks for the X series all carry a "C" after the width (54C for example).
   / Will a X series deck fit a 400 series? #4
Yes, i think it would take quite a bit of a mod to get it to work.
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Heritage HC72 Rotary cutter (A53473)
Heritage HC72...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2003 Ford F-150...
Cummins 6-Cylinder Diesel Engine with Transmission (A51692)
Cummins 6-Cylinder...
