Rake Will a ROOT RAKE do the job?
   / Will a ROOT RAKE do the job? #1
RJG
Ontario, Canada
Hello experienced grubbers;
I am considering buying a root rake for my mini excavator. In addition to general raking and cleaning up, I want to clear some 1/2"-3" brush - mainly thorn brush and other small trees as well as remove stumps that were left over from some bush hogging.
Will a root rake be able to cleanly remove this brush and pull up their root system as well?
What about for removing the remaining 1/2"+ small stumps from past bush hogging?
I was also considering building a custom root rake that would include wedged teeth between the tines. This would give me more of a 'brush brute' grabbing feature yet also provide all other benefits of a root rake.
Has anyone used a root rake for the jobs I'm trying to do or customized one like I am thinking about?
Thanks for any and all feedback!
RJG
   / Will a ROOT RAKE do the job? #2
Check the rental businesses in your area. I'd check with equipment dealers too. Often, they'll either rent or let you demo an attachment to see how it works out.
AKfish
I've launched the request to my dealer.
Thanks AKfish
...RJG
   / Will a ROOT RAKE do the job? #4
I live in an area with alot of buckthorn from small to three inches round trees.I bought a ripper tooth and a thumb for my BX24 tractor .I like it because it dosn't tear everything up. It pulls the roots out and leaves the ground loose and not dig up. A follow up to digging up Buckthorn .There are alot of seed ready to respout so in the following spring a year later. When the ground is wet and soft I pull alot of small little seeding up. Its a pain in the ###. I dont want to spray anything that will kill other plants
That is interesting... I would not have thought that a single tooth ripper would have been effective. Thanks for the post.
RJG
1998 Featherlite Gooseneck Trailer (A50514)
1998 Featherlite...
7046 (A50322)
7046 (A50322)
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
