Rotary Cutter Will a 5' KK rotary cutter fit the JD I-match
   / Will a 5' KK rotary cutter fit the JD I-match #1
gordon21
Veteran Member
Lake Lure NC
JD 790
Will a 5\' KK rotary cutter fit the JD I-match
Model L-60-40-P 5' wide 40HP gearbox model
Will it hook up to the CAT 1 JD I-match without any alteration needed?
   / Will a 5' KK rotary cutter fit the JD I-match #2
Re: Will a 5\' KK rotary cutter fit the JD I-match
Depends on the spacing of the lower stubs (pins), and if the top hook can slip under the top link attachment. Also, need to have the accomodation for the free movement of the 'tail' of the cutter. I use a chain on mine. (see attached)
   / Will a 5' KK rotary cutter fit the JD I-match #3
Hmm... chains on your hog? Don't intend to hijack this post -- but did you remove the solid, steel braces from the toplink and replace them with chains? If so, what are the advantages of doing that? Thanks for the response.
(Yah, I'm kinda thinking about a q-tach and a mower.... so, thanks again.) /forums/images/graemlins/wink.gif
2018 Kubota U17 (A53317)
2018 Kubota U17...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
NEW TRAILER PARTS & 20 CONTAINER (A55745)
NEW TRAILER PARTS...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
Hose Reel (A55758)
Hose Reel (A55758)
