Actually, I don't think that is quite true. I think they are designed to be held down, and lifted from the four corners (except on some of the longer ones such as 48 and 53) however when they are sitting on a chasis, the two rails which make up the frame of the chasis is holding up the entire box, as it runs under the box from end to end. Also, since he probably isn't going to load it to max load limits (20K to 24K for some forklift loads per foot) it is most likely that the extra blocks would be a help in keeping the box from sinking rather than adding extra support to the box. I would not hesitate to add several rows of the flat solid 4x12x12 blocks, if that is what your choice is, but in reality it would be cheaper and better to just use RR ties or other solid wood blocks. If you do use the concrete blocks, add a piece of treated wood between the container and the block to prevent cracking the concrete.
David from jax
