WildKat rock bucket
   / WildKat rock bucket #1
Cowboy Billy
Michigan
I knew I had a problem with rocks on site 1 deer food plot. It was late but we wanted to combine the rye off the field first and see if our old early 60's Oliver combine would work. It wasn't real thick but we got 3/4 bag of rye off of it.
There were way too many rocks in it to be able to plow, disk or rotill it. So had to use a set of brillion spring tooth harrows on it. I'm surprised I didn't break them. It was bringing my 65 hp Massey tractor to a complicate stop and I was having to lift them move forward a few feet and drop them again.
Since I knew I wasn't going to pick them by hand I bought a 66" wildkat rock bucket with teeth for the skid steer. It has a vertical 3/8 steel plate every three inches so it collects the 3" and bigger rocks and lets the dirt fall out. One part I messed up on is that I should have worked up the ground a few times over a month or two. All the plant stems really plugged it up and wouldn't let the dirt fall out.
Technique wise I am still trying to figure out the best way. I found out real quick filling the bucket and trying to shake the dirt out doesn't work real well. The best way I have found so far it to push forward a foot or so until I have a pile of dirt and rocks at the end of the bucket and roll it back hard. The rocks will fly to the back of the bucket and most of the dirt will fall out. Also trying to get the bucket more than 1/3 full just takes way too much work. The dirt sits on top of the rocks and doesn't fall out very well. With the technique I have so far it definitely works better with a hydrostatic machine. It would be a whole lot more work if I had to clutch and shift. As well as a lot of wear and tear on a clutch.
I am really glad I got the teeth on the bucket. It really helps pry up the rocks. And it penetrates rocky piles better than my Case W14 wheel loader that weights 10000 lbs more that the skid steer.
Out of this little area.
I got this pile of rocks. It doesn't look too big but its a good 6' high.
Once I got the bigger area worked up. I found it was a lot faster to use the dump truck so I didn't have to travel as far with my 1/3 bucket load of rocks. All together I spend three long days working up the ground and picking the rocks. I got 7, 1/2 dump truck loads of of rock out of the bigger area and dumped them in the gravel pit. But forgot to take a picture of it. The old blue truck is so tall I couldn't dump the bucket when I got much more than a 1/2 load in the truck.
It was amazing to me the size of the rocks the spring tooth's pulled up.
But finally on the 14th I had all my brassicas in and waiting on rain. The only thing I didn't do was fertilize. I didn't want to try to mix it in and bring up more rocks. Hopefully I can be up just before a good rain so I can spread it and have the rain soak it in. But I think its looking pretty good.
And the reason for all the work?
Billy
   / WildKat rock bucket #2
Nice writeup. I'm sure it will be useful for many people to see how you transformed that land into a beautiful plot. Well done!
Thanks Ted
A rock bucket it really handy for moving firewood too. When using a regular bucket to scoop firewood I would almost always get a slug of dirt with it. But with this bucket the dirt and wood chips fall out.
Where I am at is all woods. Every field and trail I had to put in. My driveway goes across 1/4 mile of my Uncle's property just to get to ours. When my Dad and brother got the last 80 that adjoins my 40. My brother was wondering why we got it as we would never be able to get up there and use it. But 6 years of hard work and its starting to look like something. That field has so many rocks sticking up I was beating my mower to death. Plus I just like watching it grow and the deer eating it.
This is what it looked like two years ago when I started making the field.
But its worth the work as it right across from my covered porch.
Billy
   / WildKat rock bucket #5
Nice job. Year 2 will yield less rocks as will year 3. Thereafter you won't be rock farming. Looks great, nice scenery !!
   / WildKat rock bucket #6
Looks like you lost your HAT in the Third picture.
I had Wildcat make a custom bucket for me. I wanted to pick up more that the rock bucket would handle. The rock bucket let too much debris go through for my liking, so I sent them a 4'x8' sheet of perforated steel with 1" holes. I made like a Soup Colander Bucket. For my needs it's amazing. Since I deal it essentially beach sand. I scoop it up and all the sand drops out and leaved everything 1" or bigger in the bucket. Twigs, glass, stones, rubbish, etc. Sort of like using a sifter.
No better way to clean up and only leave fine material under 1".
Hi Rusty
Hope ya get one. It did a good job it would have been nice if the spacing was a little tighter a 3" rock is still a pretty big rock. But then again with my soil the dirt probably wouldn't have come out very well.
Thanks Joe
I was only able to work up about 10" with the spring tooth harrow and by time I got all the rock out that only left me with abut 6 inches of loose soil. So I am sure I'll be doing it again as you say.
Howdy Cat Driver
I've 12 years in the operating engineers so I've ran a few Cats too. Yep thats my had I put it down as a reference to the size of rocks. Good idea on the bucket. But I don't think it will work for me unless I made it removable. While that field has a lot of sharp sand a lot of my fields are clay. A friend looking at the pictures said I had a nice crop of potato's. Which reminded my uncle has a old horse drown potato digger I can use once I get all the big rocks out.
Howdy CJ
Yep eastern UP by Cedarville.
Billy
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
2020 John Deere 9470RX Tractor (A53342)
2020 John Deere...
Electric Concrete Mixer (A51573)
Electric Concrete...
2008 JLG SKYPOWER 800AJ MANLIFT (A51246)
2008 JLG SKYPOWER...
