Wife's PC Died
   / Wife's PC Died #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Wife\'s PC Died
I call it my wife's computer because she's the one that uses it the most. The kids have their own and I use my laptop.
Yesterday, with all the snow, the power went out a couple of times, just for a few seconds (we were lucky and did not lose it for hours as some did), but enough to knock the PC down. I have it behind a UPS, but that must have a dead battery. Nothing else connected to the UPS was affected.
It's a Gateway PC and it will display the 16.0 MB on the video card, then it displays the full screen Gateway logo and that's where it stops. Any ideas?
Right after the Gateway logo appeared (which I assume was generated by the BIOS), it would get a progress bar in the upper left hand corner. When the progress bar was completely filled, Windows2000 Pro would start booting.
My wife is not going to be happy /w3tcompact/icons/sad.gif since she will not be able to play Mahjongg or get her email.
   / Wife's PC Died #2
Re: Wife\'s PC Died
Well... at least it's still breathing... /w3tcompact/icons/wink.gif
Could be corrupt CMOS or W2K system...
Easy test... sub another HD to boot from to determine which direction you will go...
Try resetting CMOS by "clear" jumper and removing on-board battery for ~ 15 minutes...
Gots to bring the wife to work... Good luck... (lots of snow!) /w3tcompact/icons/smile.gif
   / Wife's PC Died #3
Re: Wife\'s PC Died
Try setting up a boot floppy from your laptop (or something with the same OS as the wife's PC) and boot her PC from that. This way you will have a chance to see if the HD is dead or just scrambled (and you don;t even have to crack the case).
   / Wife's PC Died
Re: Wife\'s PC Died
Thanks for your replies, Andy and John. It wont boot from a floppy or CD. I've tried holding the Esc, F1, F4 and F8 keys while booting and nothing gets me into the CMOS. It looks like the CMOS is dead. /w3tcompact/icons/sad.gif
   / Wife's PC Died #5
Re: Wife\'s PC Died
Normally, entering BIOS requires the F2 or Delete key. The "correct" key to use is probably hidden behind the Gateway logo screen. However, just for giggles, try the F2 or the DELETE, but not both simultaneously. Do this as soon as you see the logo screen.
Not sure going into BIOS will help you though. But, it is a possibility the BIOS may not be recognizing the hard drive.
If you get into the BIOS, you'll have to see what's there for the drive, if anything. Hopefully, the BIOS can autodetect the drive if it's not being recognized.
As mentioned by another poster, you can pull the battery or change the jumpers (if your board has jumpers) to clear the settings. If you don't have the mainboard manual, don't mess with the jumpers.
If you want to try pulling the battery, make sure you disconnect the PC power cable first.
   / Wife's PC Died #6
Re: Wife\'s PC Died
If it were mine, I would remove all cards from the machine and see if it boots then. If so, add back one card at a time until you've found the one that took the hit (perhaps the modem.. if she has one.)
This is a common experience we have when there are power glitches.. and you'd be surprised how, if a card gets zapped, it can bring down the entire system.. to the point it won't boot at all.
It could also be one of the drives, even the floppy. Try disconnecting them and see what happens, if the card trick above doesn't help.
HTH,
Bob
p.s. Make sure you are grounded, by touching a metal part of the machine chassis, when playing with the cards, so you don't zap one with static electricity. Also, without any drives connected, you should at least get to the point where it says something like "Operating system not found; insert system disk." This would be further than you're getting now, and would be a good sign that you may have found the problem.
   / Wife's PC Died #7
Re: Wife\'s PC Died
I had the same thing back in November. 3 short power outages over 3 days. Then the computer would do like you said. Start to boot, go check the video card, then nothing. Do what Trev suggests. Remove the cards and see if it boots. Also, if you have several memory sticks, try removing all but one and see. Unfortunately, mine turned out to be several capacitors on the mother board got blasted. And that was behind a surge protector power strip. Someone told me that the surge protectors on the power strips can only take so many surges, then they are no good.
I was pretty angry, as the motherboard had built in IDE RAID that I used for backups. The board is no longer made and it is getting harder to find socket 370 mother boards for P3's. I ended up with an Intel board that was only $79.00.
And, since I documented the power outages, the power company had records of when it occurred and found that a homeowner had dropped a tree on the lines and caused the initial outage and the subsequent outages were due to repair work. They had 5 other damage claims and told me to FAX them the bill for the new motherboard and they would cover it. We'll see what happens with that one /w3tcompact/icons/tongue.gif
   / Wife's PC Died
Re: Wife\'s PC Died
Thanks to all.../w3tcompact/icons/smile.gif I tried the Del when I saw the logo, nothing. I powered off and on then tried the F2 key....Nada. I'm off to try pulling boards one at a time. /w3tcompact/icons/frown.gif
   / Wife's PC Died #9
Re: Wife\'s PC Died
<font color=blue>I'm off to try pulling boards one at a time.</font color=blue>
No, not one at a time.. all of them at once. If you have two bad cards, you'll never figure it out unless you remove them all and then add each one back and test. Kind of like skunks, these computers.. they do make scents.. sort of. ;-)
Bob
   / Wife's PC Died
Re: Wife\'s PC Died
An interesting development...
My PC, a tower, sits underneath a shelf so I have to pull it forward slightly to unhook all the cables. Before I unplugged the last two cables, the monitor and keyboard cables, I tried one last time to boot it. Guess what? It booted fine. /w3tcompact/icons/hmm.gif
By process of elimination I've determined that if my USB hub is plugged into either of the on-board USB connectors, the PC will not boot, yet, if I plug the hub in after the system is up, Win2K recognizes it just fine.
I've had this PC for a couple of years and the following on-board ports/devices have gone bad;
1. Sound card - had to buy a separate PCI sound card.
2. One of the two serial ports. Since I switched to DSL, I don't need them, but still...
3. Now, the USB ports.
Without the USB ports, I do not have access to my scanner, CF/SM card reader and Palm docking port. /w3tcompact/icons/sad.gif So, I don't think I will cancel the order I placed earlier this morning for a new PC. /w3tcompact/icons/clever.gif It was time to upgrade anyway.
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
6 BENCH GRINDER (A53843)
6 BENCH GRINDER...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
TURBO SAW SKID STEER ATTACHMENT (A53843)
TURBO SAW SKID...
