Tires Widest width for L3400 w/ R1 tires ?
   / Widest width for L3400 w/ R1 tires ? #1
Arky217
Hartford, AR
Kubota L4200
What is the widest width a L3400 can be adjusted to ?
This would be from the outside edge to outside edge of R1 tires.
Can spacers be added for even wider width ?
Also, can the front width be adjusted; if so how wide ?
Does adjusting wider have any negative effect on the wheel bearings ?
Thanks,
Arky
   / Widest width for L3400 w/ R1 tires ? #2
It always is an issue to widen more then is what is needed. It does cause extra stress on the axle shaft as well as all of it's support the bearings and housings have seen all failed from this type of excess stress.
Chances are that the manufacuter built it to go there and if used "properly" the life difference would be not be noticable.
Normal setting is about 60" in the rear and I believe there is about six more inches to maximum.
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2016 TRAIL-EZE TE80HT 102" X 48' STEP DECK TRAILER (A51243)
2016 TRAIL-EZE...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
