Widening track on an LB1914
   / Widening track on an LB1914 #1
torry61
kioti LB1914
The owners manual on my Kioti tells me you can widen the track to improve stability on grades, (I live in the MO Ozarks, NOTHING is flat here!) It tells the owner to exchange the rear tires from left to right & vice veras??? Problem is how do I know that this hasen't been done already. What is the max when the tires are exchanged? The track is it stands now is 48" to the outside tread of the back tires. How does flipping the tires widen the track???????????????
Torry
   / Widening track on an LB1914 #2
The rims have an offset. Look at them very closely, or better yet measure from the inside of the rim (the area that bolts to the hub) to the outer edge of the rim. There should be a difference on one side, as compared to the opposite side of the tire. To measure it, lay a board all the way across the rim, then measure to the mounting flange area. Put the board on the opposite side of the rim and repeat, but try to use the same reference point on the flange area. I know that probably wasn't explained very well, but if you think about some, hopefully you will understand what I'm getting at.
Go to this link and scroll down:
http://www.millertire.com/FAQs.asp
Once you figure out which side of the rim has the most offset, that side of the rim should be on the outside (facing away from the hub). Typically you can do the same with the front tires too. I know the front rims on mine can be swapped for a wider or narrower stance. Good luck.
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
WIGGINS 5K FORKLIFT (A52472)
WIGGINS 5K...
