Widening disc
   / Widening disc #1
Mallard1
Arkansas
John Deere 4320
I have a old 5ft angle iron disc that is pretty similar to this
King Kutter Angle Frame Disc Harrow 5 1 2 ft Notched 16 16 G N YK | eBay
It is needing new bearings, housings and a blade or two this winter. I would really like to have a six foot disc. Is it possible to just add the spacers and new longer shafts and just add a blade to the end of each shaft? Thanks for the help?
   / Widening disc #2
Possible? Perhaps.
Advisable? I don't really think so, no.
Two reasons:
1. Expense of buying/making the necessary parts - the longer axles you could maybe make, the spacers and disk blades you'd have to buy.
2. That's a pretty light duty frame. I'd be worried about the extra side-loading from the increased length twisting the frame or bending the brackets that the axle bearings are mounted to.
OTOH, if you can kludge it together from pieces-parts you have laying around, I guess it couldn't hurt to try. If it folded up, you could just go buy the 6' disk you want. :)
   / Widening disc #3
In my opinion a Disc Harrow with 16" diameter pans is too light to mix soil that has any significant clods and will float over many plow furrows.
A Disc Harrow with 18" pans is marginal. Disc Harrows really work well only with 20" diameter and greater pans.
A PTO powered Rotary Tiller is much more effective than a Disc Harrow with 16" diameter pans.
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
