Why one vs. three tines for a bale spear?
   / Why one vs. three tines for a bale spear? #1
bxowner
Vermont
John Deere 5055e
As the thread name suggests, I am wondering why I'd opt for a single tine over a three tine bale spear attachment. Three seems more stable - I can't imagine the savings are that much.
Anyone have an opinion or experience?
   / Why one vs. three tines for a bale spear? #2
I prefer the bale fork which has 2 long spears at the bottom. I can use it to move hay or logs or brush.
   / Why one vs. three tines for a bale spear? #3
The bale spears I've seen have one big centered spear and two small stabilizing spears, lower and to each side, are for round bales. The three spear bale spears with three spears same size and in a row at the bottom are for large square bales.
   / Why one vs. three tines for a bale spear? #4
With 3 spikes when stacking you spear them off center to get into a tight spot. With one it will just rotate/swings until gravity finds center. When they stack here they use all 3 spikes. Luckily we bought a QA Spear that you can remove the 2 short stabilizer spikes. My wife feeds her cattle by spinning hay off into troughs, it would be impossible to do that the stabilizers in place.
   / Why one vs. three tines for a bale spear? #5
Absolutely. The only advantage of a single spear is initial cost. After you write the check, it's all downhill.
   / Why one vs. three tines for a bale spear? #6
I just use a muck fork (6 tines) and remove half of them for bale work. The muck fork cost about the same as a purpose built 3 tine bales spike, and has the advantage I can also move muck, grass and even unload light pallets with it.
Definately would recommend more that one tine for bale work - you'll notice the difference over single tine spikes, even on round bales. :thumbsup:
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
