Why oh why
   / Why oh why #1
valker
Kubota and New Holland
Why doesn't a TC30 have any down force on the loader boom arms?
   / Why oh why #4
Maybe he has a loader with 2 positions (power or height) and sometimes if the loader is in the height position, it’s not well suited for lifting the tractor up because it sacrifices power for lifting height.
   / Why oh why
Ive never seen a tractor without down pressure. Are you sure your not pushing lever too far forward and pushing it into float mode
No, not in float mode.
   / Why oh why
It should have down force. It should lift the front wheels off the ground
With boom arms down you can curl the bucket and lift the front wheels off the ground. I have owned 2 TC30's a 2008 geared and this 2004 HST and both the same way.
   / Why oh why
Doesn't someone else own a TC30??
   / Why oh why #9
When the boom arms are "down", are the cylinders completely retracted? If so, you just don't have any more travel for that cylinder. If you put a jackstand or railroad tie or some kind of block under the bucket -- then will the FEL lift the front?
   / Why oh why #10
I had aTC30 25 years ago with plenty of down pressure. Lots of unanswered questions in your brief posts. How long you owned it, factory or aftermarket, and on and on.
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
John Deere 1025R (A53317)
John Deere 1025R...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
Bell 1600 Gallon Nurse Trailer (A56435)
Bell 1600 Gallon...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
