Why is my 1725 loud?
   / Why is my 1725 loud? #1
dirthack
The engine on my 1725 makes a lot of noise. It's not from the exhaust, it's the typical "ratta ratta ratta" diesel engine noise. The 1725 is a 29 hp. My buddy's TC25 with 24 hp engine is very quiet in comparison. Is it just the nature of this engine to be noisey or is there something wrong with it? I guess maybe I need to hear another 29 hp NH tractor to compare. I thought about adding some insulation to the underside of the hood.
Any thoughts?
   / Why is my 1725 loud? #2
Go to your local dealer and test drive a 29 or 33 and seem what you think. They should be somewhere around the same as yours but each motor ends up with it's own characteristics.
murph
   / Why is my 1725 loud? #3
I have a 1720, same tractor more or less, yours might be built with less creature comforts, more for long lasting & durability - such as that fuel shut off you mentioned, wish I had that instead of the selinoid the 1720 comes with. Electrical stuff fails, costs more to fix, and leaves you sitting in the field. A mechanical unit can often be repaired in the short term with baling wire. /forums/images/graemlins/smile.gif
Anyhow, can't really help with noise, unless I hear it. Older & bigger engines will make more noise. How hard would be be to have a mechanic listen to see if it's a piston or wrist pin knocking?
--->Paul
I'm pretty sure it's just the nature of the engine. It's definitely the normal ratta ratta ratta diesel sound, just too much of it. I wouldn't think anything of it if wasn't for my buddy's TC25 which is noticeably quieter. But hey, I have 4 more HP.
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
vin:16VEX2023H3042174 (A50322)
vin:16VEX2023H30421...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
