Why does my trailer suspension keep breaking?
   / Why does my trailer suspension keep breaking? #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Several years ago I rebuilt my 10,000lb flat be trailer. New tires, fenders, springs, lights, ect. To do this work I flipped the trailer over. At that time I noticed that some of the spring mounts were rough so I replaced them. Fast forward a few years later... I had loaded my skid steer (7,000lb machine) and made a u-turn when I heard a "bang!". Stopped to check the trailer and found the left rear spring shackle had broken off. The weld did not fail, instead the the two tabs ripped right off the U. Attributed that to a freak occurrence until last night. I had just transported the same skid steer 2.5 hours at 75mph without an incident. Unloaded the machine and transported the trailer 15 miles, some of which was over a very rough road. When I got to my destination I could smell something hot. Check the brakes and they were cool. Noticed the tires were shifted together and had burned each other down significantly. Sure enough the right rear spring shackle broke off. Same shackle and before, but now the opposite side. It was dark or I would have taken a picture. Just like the last time, the tabs broke off the U, but the welds held. The break is very jagged, like the metal ripped. The break is bright and not rusted. Definitely not the result of a brittle weld. WFT is going on here?
   / Why does my trailer suspension keep breaking? #2
I would say without looking at the whole trailer is a misalignment under load. CJ
   / Why does my trailer suspension keep breaking? #3
The tires are dragging on very sharp turns cause to much side tension. I've often wondered why more haven't broke when I see travel trailers in parking lots doing sharp turns and the wheels torching out of alignment. This would be most detrimental when loaded.
   / Why does my trailer suspension keep breaking? #4
It sounds like either the shackle was to light or the weld was wrong in some way you don't see or both. Did it break at the weld? how big was the grain in the metal at the break? Ed
   / Why does my trailer suspension keep breaking? #5
Just a guess but I agree that sharp turns but a heavy load sideways.
   / Why does my trailer suspension keep breaking? #7
Never seen that one. Perhaps you bought replacement ones that were "cheap"
Chris
   / Why does my trailer suspension keep breaking? #8
What are you running for air pressure in the tires ? Increasing the pressure will lessen the tire scrub. How close are the axles ? Decreasing the distance will lessen the tire scrub.
Rough road damage is fatigue (coat hanger).
   / Why does my trailer suspension keep breaking? #9
It seems pretty clear that your replacement spring mounts are not strong enough. A 10,000 lb gross trailer with a 7,000 lb load is probably at the max GVW.
Is it really a good idea to tow a fully loaded trailer at 75 MPH? I think that endangers everyone else on the road.
   / Why does my trailer suspension keep breaking? #10
Obviously too much load for the load bearing parts. Could be as simple as the U bolts not being torqued; right allowing them to work harden combined with unrealistic speed (stress) and rough roads (again adding stress). My trailers never go over 60 and that is only on the freeway. Yeah, people honk and give the one fingered salute, but I may be saving their life.
Ron
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
(1) HD 24ft Free...
8ft x 6 1/2ft Shipping Container with Side Door (A51573)
8ft x 6 1/2ft...
1067 (A53342)
1067 (A53342)
