Why does Internet Explorer keep shutting down on me?
/ Why does Internet Explorer keep shutting down on me? #1
rox
Veteran Member
Salon De Provence - France
Recently I got a windows upgrade and got the new version of Intenet Explorer that has tabs. I use my middle moue button to click on links and open the linked webpage in a new tab. Fairly frequently, especially when I have a lot of tabs going, when I click on a link to open a web page in a new tab the whole broser closes down on me. does anyone else have this problem/ does anyone know a fix/ Thanks
/ Why does Internet Explorer keep shutting down on me? #2
I've been on since this morning and no problems here at all. Now I did DL IE-7 and I had a world of problems with it and I removed in and I'm on IE-6 and happy
Jim:)
/ Why does Internet Explorer keep shutting down on me? #3
IF it's the IE7 upgrade, that's most likely the cause. Bad news and many problems with it. I had a PC at work that was set for automatic updates and IE7 was downloaded...what a nightmare. Even after removing it, still had problems. Fixed everything buy using system restore and going back to IE6
thanks guys, although i am diappointed that the solution is to go backwards. hopefully with some time on this message board others will come up with a solution other than "un in stall it' i do like the tabbed browsing. i used to always open thigs in a nw window. the tabs are nice. I msut confess that i am too lazy to download and try other browsers. i jsut stick with ie. i ahve so much other stuff to do, I jsut don't want the aggrivation of swithcing to a different browser. again thanks for replying
/ Why does Internet Explorer keep shutting down on me? #5
You might download firefox. I use it for browsing. Not nearly as many problems IE. Also, it will automatically transfer your current setting from IE. Then you won't have to rollback your computer either.
JK
/ Why does Internet Explorer keep shutting down on me? #7
Ditto on the Firefox - best ever, on the PC and the Mac.
EanJay
/ Why does Internet Explorer keep shutting down on me? #9
Wow, I'm the opposite; IE6 drove nuts with constant crashes. I've not had any with IE7. Firefox is not compatible with most every business site I have to frequent for work. And, no, I haven't the time nor desire to download 6 dozen add-ons to Firefox to get it to work. I liked it, but it was loaded with problems with compatibility with business sites. The one feature I really liked was the tabs. That was picked up by MS with IE7. Firefox on longer resides on my machine. I guess if I did no business on on secure sites with my machine I may have liked Firefox but, unfortunately, that's not the case for me
/ Why does Internet Explorer keep shutting down on me? #10
I must be one of the lucky ones. Switched over to IE-7 on three computers with no problems.
Still use Foxfire, but getting more used to IE-7 and like it better.
/ Why does Internet Explorer keep shutting down on me? #11
IE 7 on three machines also. No problems with any site, business or pleasure.
/ Why does Internet Explorer keep shutting down on me? #12
And I don't even know what they're talking about when they mention "tabs", but I just now downloaded IE 7 so I'll see if it's better or worse, or maybe I'll only see whether I'm better or worse.:cool:
/ Why does Internet Explorer keep shutting down on me? #13
I like Tab's. It allows me to have more than one Internet site open without opening up another IE session.
/ Why does Internet Explorer keep shutting down on me? #14
What's the difference between "tabs" and having multiple windows open?:confused: Besides the fact that the windows are at the bottom the page and the tabs at the top.:D
/ Why does Internet Explorer keep shutting down on me? #15
May be wrong. But I believe that having multiple windows open requires more memory. :confused:
/ Why does Internet Explorer keep shutting down on me? #16
I have both Firefox and IE-7 on my computer. I will switch back and forth but mostly use firefox. I like it's spell check firefox has. But I have had no problems with IE 7 what so ever.
murph
Everybody,
Thanks for your inputs; it either crashes and people never fixed it ,they rolled it back to an earlier version, or it works fine.
I went to Manage Add ons and inactivated a couple of them. And that has not helped either. I am at the point where I am getting pretty good about knowing when it is going to shut down on me. Just before I click on a link I say to myself, "I bet this is going to close the browser' and I'm right most of the time. I ahve a pretty good computer 512 mg of ram and a 100gig hard drive, can't remembe the processor but it is a fast one. So I really don't think it is the hardware. There is something interfering, so cash size of something or other that is jsut closing me down regularly.
I'll keep checking back in case someone has had the same problem as me and has fixed it. I have high hopes that someone around TBN will know how to fix this.
Bird, i wish you well, I hope you fare better than I did. I like the tabbed browsing, it is a lot neater/cleaner than opening a new window. I always used to open jsut about everything in a new window.
/ Why does Internet Explorer keep shutting down on me? #18
Rox, with IE 6, it used to just shut down unexpectedly every once in awhile, but hasn't done it in quite awhile now. And so far, with IE 7, it hasn't happened, but who knows when it might start.:rolleyes:
/ Why does Internet Explorer keep shutting down on me? #19
Been using Firefox for about 3 years now & never had any problems opening any sites I've visited. Due to some self-inflicted trouble (adding a 2nd hard drive) I upgraded to Firefox 2.0 & I couldn't be happier. Still has tabs, but I find the built-in spell check MOST helpful. I would highly recommend it for casual browsing (I keep IE6 as a back-up). Try it! I doubt you'll be disappointed. BTW, I just refused the EI7 "upgrade" a couple days ago.
/ Why does Internet Explorer keep shutting down on me? #20
I had the opposite problem with IE...it would START UP on it's own. At that time I was on a dial-up so it didn't connect to the internet without an OK, but it obviously had been corrupted by spyware or something.
IE is the most hacked software out there, simply because most people use it. That alone is reason enough for me to avoid it. Plus, I have yet to encounter a site that Firefox won't open.
Brent 420 Grain Cart (A63118)
Brent 420 Grain...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
17394SFL (A61568)
17394SFL (A61568)
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
