Why do plasma cutters cost so much?
/ Why do plasma cutters cost so much? #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
I watched someone use a plasma cutter the other day, and he explained it's basically an arc cutter, that blows air around the arc. If that is true, why are they so expensive?
If not, what makes them expensive?
Thanks, that helps some. Didn't understand all I read.
/ Why do plasma cutters cost so much? #4
Jim Colt is the man to ask. He'll likely be able to tell you all you ever wanted to know.
A quality plasma and a quality mig capable of working in the same size materials are about the same cost. Plasmas are "expensive" but not really relative to other metal working equipment in the same class.
Yea I suppose when you get into the "quality" welders, unfortunately, I cannot afford either, quality ones that is.
/ Why do plasma cutters cost so much? #6
I'd like a plasma too but at $60/hr for laser cut parts, it would take a lot of work to justify one!
Of course I can draw and nest my own parts so that helps.
/ Why do plasma cutters cost so much? #7
I think you also have to remember that like everything else products that are in higher demand can usually be made cheaper by making the manufacturing process more efficient. Most people who are new to metal working will buy a welder (or two) before they even think about getting a plasma cutter. That assumes that they will not just pick up a used set of O/A (or even cheaper Propane) torches. Plasma cutters are usually more thought of as a "luxury item" with people who have limited money and room in their shop.
/ Why do plasma cutters cost so much? #8
Ford, Chevy, Porsche
They get you there but the cost is the difference.
RC
/ Why do plasma cutters cost so much? #9
There are low cost plasma cutters (under $500) that can cut up to about 1/2" thick...and there are more expensive industrial grade plasma cutters for cutting up to 1/2" that sell in the $1200 to $2500 range. There are air plasma 's (lowest cost, portable) and there are plasmas that can cut over 6' thick stainless steel at 1000 amps...that cost in excess of $100,000. Just like anything else there is a wide range of capability, a wide range of quality and reliability, as well as a wide price range.
The plasma torch develops an ionized gas (air in most small units) that becomes electrically conductive....the gas is forced through a nozzle orifice and DC power (similar to welding power...but typically much higher voltage) is applied to the gas stream ...this power increases the temperature of the gas stream to as much as 50,000 degrees fahrenheit. The high temperature arcs velocity increases dramatically as it passes through a small nozzle orifice...and the combined high temperature and velocity can melt any conductive material and blow it out the bottom of the cut as molten droplets.
The better plasma systems (major manufacturers, typically higher priced) do a much better job of controlling the shape of the arc and also controlling the heat in the torch and consumables...resulting in very nice cut quality at very high speeds, and with a very low operating cost (long consumable parts life). Lower cost units with lesser technology typically will be less reliable under high duty cycle usage, will use a lot of consumable parts (costly) and will provide lesser cut quality. Think about the design and physics of a plasma torch producing a 50,000 degree high velocity arc......how does it stay cool, how do the consumable last for thousands of cut cycles?
In industry, plasma is the product most often used for cutting steel, aluminum and stainless from gauge materil to about 1-1/2" thick....mechanized cutting produces amazing cut quality at speeds that are over 6 times faster than oxyfuel, and mfaster than a C02 laser on materials thicker than 3/16". Plasma , primarily due to its high cutting speed is the least costly, most productive way to cut most metals. Laser is most often used on thinner materials, water jet is slow....and used on materials or parts that cannot tolerate a heat affected zone.
The big advantage to plasma is with todays hand held plasma cutting systems.....portable devices (the Hypertherm Powermax30 as an example, is the size of a two slice electric toaster, operates off a 120 volt circuit and 4.5 cfm of regular shop compressed air.....cuts 1/4" metals with ease and can sever 1/2" steel) that have been used in place of many other metal cutting methods for about 5 decades. With the latest inverter based power supply technology...these systems can be small, reliable, and can cut with exceptional quality, ease and speed.
There.....that's why plasma can be expensive!
Jim Colt
/ Why do plasma cutters cost so much? #10
Jim didn't mention that Harbor Freight doesn't sell quality plasma cutters. My first plasma was a small Hypertherm. As soon as I tried to do meaningful work, cut a 12 inch diameter pipe into two equal pieces, lengthwise, I returned it and got a "healthier" Hypertherm which does pretty good considering my poor skill level. Given my poor skills with OA cutting torch, a plasma cutter is like having the cavalry to the rescue.
Pat
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A60429)
2022 BOBCAT T76...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
