Why do I see HP listed as 37.5 and 38.5 for the 2605?
   / Why do I see HP listed as 37.5 and 38.5 for the 2605? #1
cmore
nw tn
traded MF135 for a 2605 4x4 &added a Mahindra eMax 22HST
Just wondering why I see both and which is correct?
   / Why do I see HP listed as 37.5 and 38.5 for the 2605? #2
There are generally several HP's listed for an Ag tractor; the max Hp of the engine at the engine ouput shaft; the pto HP at 540 pto rpm; drawbar hp(drawbar force x velocity /550) and this is determined by test.
tractordata.com says the MF2605 has 38 Hp at the engine and 32 hp at the pto with live pto and 30 hp with independent pto.
Just a thought. Could those differences by 1HP be in regards to hydrostatic and gear driven?
No, as the 2605 only has manual trans available. A brochure from MF lists 38.5 in 2 places so guess that is the correct # for the current model.
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A51247)
2001 WELLS CARGO...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
CFG Industrial SAII100 (A50123)
CFG Industrial...
