JohnDeere4300
Veteran Member
This problem just started tonight, after i post on a thread i go back
later and i see where i can__edit__ my post.
Can I edit or delete my posts?
If you have registered and are logged in, you may be able to edit and delete your posts (although the administrator may have turned off this option). Your ability to edit your posts may be time-limited, depending on how the administrator has set up the forum.
To edit or delete your posts, click the Editbutton by the particular post. If your post was the first in the thread, then deleting it may remove the entire thread.![]()
Once you've made your modifications, a note may appear to inform other users that you have edited your post.
If the edit time and date appear as a link you can click on this to see the differences between the original and edited versions, or between edits if there have been multiple edits.
Can others edit my posts?
Administrators and moderators may also edit your messages. If they do, there may not be a note telling other users that the post was modified.
The following is copied from the FAQ:
I may be wrong, but to the best of my recollection, you've always been able to edit your own posts for about 12 hours after you post a message.
I am good at seein em after they are posted; but I ain't no good at all at editing or deleting them when the edit feature don't function!Why do i see edit after i post?
That's for people like me who can't see obvious mistakes until after it is posted!![]()
