I now have a big enough tractor to only need a heavy duty rear blade. The days of a 3-point blower and going in reverse are loooong over. However, in the day - I always figured to blow, at least, two shear bolts on the first clearing of my mile long driveway. A rock, an old chunk of wood, even a frozen pocket gopher, chunks of ice. OR blowing when the snow was too wet. Stop for a moment to catch my breath and massage my sore neck & shoulders. That's all the time it would take for the wet snow to freeze up and "BING" - another sheer bolt. I always had a goodly supply of shear bolts carried on the tractor.
Unfortunately - I got real good at a fast replacement of blown shear bolts.
Are you going too fast. Are you pushing a big "glop" of snow ahead of the blower. Check that your chain is tight enough. There is an idler sprocket that will allow you to adjust chain tension.
Also - that object that has caused your bolt to shear will seldom be right there in the auger or impeller for you to find. The bolt has sheared - the tension has released. The "object" has either been blown out or is up there in the pile ahead of the blower.
Another thought - when you install a new shear bolt - it should be wrenched down pretty tight. No slop in the final fitting of the shear bolt. Slop will cause unwanted torque loads in the system.
