Why did my hydraulics wimp out?
   / Why did my hydraulics wimp out? #1
Indian Territory
New Holland PowerStar 75
Today in the 100° heat my hydraulics gave out and would no longer lift my heaviest implement. The tractor is a New Holland Powerstar 75 and is probably operating at the upper limit of its ability when lifting our Rain-Flo 2670 raised bed mulcher. I immediately suspected a combination of a very hot day and a hydraulic system that is probably working too hard. Then again, I don't really know what I'm talking about. Can a hydraulic system overheat and lose lift capacity?
I also hooked up a rented lime spreader that seemed to be poorly maintained. Could I have circulated their scuzzy oil into my clean reservoir? Would the pollution from a single dirty remote line be enough to cause my trouble? I wish I knew more about these things.
   / Why did my hydraulics wimp out? #2
If you have a filter screen it could be partially blocked. You could also have too much crud in your hydraulic filter. Was there possibly any water in the system of the attachment you used? Water could vaporize in the hot hydraulic fluid.
   / Why did my hydraulics wimp out? #3
When oil gets hot it gets thinner and flows easier which can cause some pressure loss if their are enough leak paths.
Dirty filter would usually be more of a problem when cold vs hot.
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
