Tires Why did LB1914 front tires rub on FEL Attach?
   / Why did LB1914 front tires rub on FEL Attach? #1
HickoryKi
S E Louisiana
Kioti LB1914
Monday while clearing very rough uneven terrain my front tires came in contact with the FEL attaching part positioned just above and behind the front tires. Having had this tractor over 6 years I know the axle moves in a see-saw way but the wheels seemed to push backwards. I have one bad bushing on the left side. Back on level ground everything looks normal with about a 2 inch clearance. Has this ever happened to anyone besides me? I'm concerned about going back out this weekend. An hour ago, I sat on the ground, laid down under it...everything looks normal. Thanks in advance for any pointers. By the way, i was a member before Katrina hit 3.5 years ago.:confused:
   / Why did LB1914 front tires rub on FEL Attach? #2
Lift the front end off the ground with your loader and try and see what kind off movement you have.
You did't happen to put the rims on backwards did ya?
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
