Why Can't I Edit My First Post Anymore
   / Why Can't I Edit My First Post Anymore #2
There is a time limit on the ability to edit a post. I'm not sure about that limit -- maybe it's 24 hours. If you want to add or modify your original post, "Reply with Quote" and clarify as needed.
Steve
   / Why Can't I Edit My First Post Anymore #3
Steve
Yep, its 24 hours. If you need to to remove info, you can report the post (click the "Report Post" icon (
) in the bottom left corner of the post and ask the moderators to change/remove the info.
Aaron Z
Okay thanks!
   / Why Can't I Edit My First Post Anymore #5
Steve
I wonder Steve if you can still delete at 1439 minutes? :D
   / Why Can't I Edit My First Post Anymore #6
Editing/Deleting is available for 24 hours, so as long as the server gets your "save" command before 1439:59, you should be good.
Aaron Z
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2000 FORD F-650 DUMP TRUCK(INOPERABLE) (A52472)
2000 FORD F-650...
Case 588G (A50120)
Case 588G (A50120)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Club Car Carryall 500 (A50121)
Club Car Carryall...
