why? any suggestions?
   / why? any suggestions? #1
tiltbed
Bronze Member
Ohio
ford 3000,case SI..Just purchased a 404 Futon (40 hp 4wd) with a koyker FEL
being a luker and some what poster...farmer and all around guy...gotta question..after much thought (and i do mean much)thinkin about ordering a DK40 from o'brians.but what makes Kioti any better than well say kabota or any of the others?I have looked at a mihadra (can`t pronounce the names more less spell em..lol)turn off was on the 4x4 with a fel there is a accumlator on the right side in ft and below the rear axle line which the fel support arms go under leaveing about 8" of ground clearance.I haven`t seen any bad tideings on the kioti,but there must be some miss giveings,no?presentally i own a ford,case and IH but feel the need for a compact 4x4...any and all imput will be greatly appreciated...thank you....Sid
   / why? any suggestions? #2
Sid,Having just purchased a DK40 myself I can say that after almost 50 hours it has been a great tractor and has given me no problems.
Wether it is better than any other tractor is dependent on what the purchaser needs and what any given manufacturer can provide.
What Kioti gave me was a rugged and well built machine for a lot less money than the big three.
What it didn't give me was hydrostatic(didn't want it anyway),a huge dealer network and instant brand recognition.
Having said that, I stand by my decision to go with Kioti.No matter how I tried I could not see where the other brands were $5,000 better than my tractor..........Mike
Mike,thanks for the input...i have never seen or heard of a Koiti,just ran across it on the internet.we have lots of yamars,kobotas and the big 4 i callem..NH,MF,JD,IH..from what i have ovserved from this group i am impressed with the Kioti...thanks again, But still trying to find out if there is or have been any problems with these little guys...Sid
   / why? any suggestions? #4
Sid,
We have been a Kioti dealer here in Texas for several years now and Kioti has proven itself to be a great little tractor.
If you get a Kioti tractor with a FEL try and stay with the Kioti brand loader, it was designed spacifically for that tractor, is a great loader anyway, and if you decide to ever trade it off the tractor will bring better resale than a tractor with an aftermarket loader all other things being equal.
The only troubles we have much is with the nick-nack stuff like turnsignals.....ect.
I do not think we have ever been into one for warranty work due to tractor failure, operator abuse a couple of times though.
You can tear up an army tank if a person tries hard enough.
JMHO,
K
   / why? any suggestions? #5
Hi Sid, I have a DK35 with 182 hours of hard work with no problems to speak of. I say to speak of because the seat cracked and was replaced under warranty. This tractor starts at any temp instantanously and that's in the winter without a block heater. I have used the loader to fix leaks in a pond dam where I was really loading up the loader with mud. The girl didn't even grunt. I have fluid in the rears so the girl didn't even feel light with the loader full of mud. I brus hog about 50 acres of grass/spaplings with about 10 of that being heavy saplings up to 2" diameter with no problems. Most the time I'm in hi first. I paid $15800 for it with the Kioti loader. I agree with getting the Kioti loader over the others because of the resale but the others are just as good from what I've heard. Good luck and hope this answers some of your questions.
well guys my thanks go out to you,i have not heard any bad reviews.i think that was what i was hopeing for...will place my order in late winter...early spring,before planting time.want to erect a machine garage...ford n case are outsiders...IH sleeps in the barn.can`t see spending $22,000 on something and keep it out in the weather.case and IH will be looking for new owners....i`ll let yall know how the new lil guy works out...Sid
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
Drill Bit attachment (A50322)
Drill Bit...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
John Deere 825i Gator (A50514)
John Deere 825i...
