why after yrs of use, hyd level high & leaking
   / why after yrs of use, hyd level high & leaking #1
sansone
live oak, FL
mahindra 2615 gear
happy with the mahindra but surprised to see hyd oil leaking out shifter boot.. not surprised to find a leak, surprised to see the hyd level high, never added any so is there a way for the level to rise from another fluid?
   / why after yrs of use, hyd level high & leaking #2
Would it be possible that rainwater is getting into the sump thru the same shifter boot?
excellent deduction, thanks ..but stored in a small barn (paid a fortune for this red rascal)
I think the level has always been high, when the dealer installed the loader they must have overfilled..
maybe it took 5yrs for the neoprene boot to give up?
   / why after yrs of use, hyd level high & leaking #4
What model Mahindra? Has it been 5 years since you checked the level or changed the fluid?
Generally when we hear of this problem it is water like koua mentioned and only on older tractors with a shifter boot that is shot and then only on the type of transmissions for which a leaky boot is up on top and can collect rainwater. Seems unlikely on a newer model that is stored indoors. If you have that much water your hydraulic fluid will be milky.
I check engine oil & water each use but sadly the hyd fluid has not been checked or changed. I always look under her (concrete floor) and if no leaks I assume the fluid level is good..
Will drain fluid and change filter today, with proper level the small hole in boot will not be a problem.
thanks for all the fast replies!
oh and.... 2615 mahindra manual tranny...with front loader and "bush hog" rough mower
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
