Why a Prodigy Brake Controller?
   / Why a Prodigy Brake Controller? #1
stuart
Virginia, Eastern Shore
JD 4300
I see it time and time again in the Towing Forum (Toyota Tundra Forum) but no one ever explains why to use the Prodigy Brake Controller. It seems high priced at $125 even though I have seen it as low as $93 plus shipping? Your thoughts greatly appreciated.
2nd Question: What color is the back up light wire for the seven pin connector on a Toyota Tundra?
   / Why a Prodigy Brake Controller? #2
Works very well, ease of installation. good value for the money. I have one in my truck and tow a fifth wheel camper, it is basically a set and forget.
   / Why a Prodigy Brake Controller? #3
I was told that it has electronic contol vs. the pendulum type. I used one in my dually for years. It worked flawlessly.
   / Why a Prodigy Brake Controller? #4
Because it's a progressive stop, much smoother than a pendulum unit. Never needs adjustment. Set it and forget it. Once you own one, you will never go back. If you want the best info on the net about towing, go to rv.net. Big forum for everyone towing campers all over the country. They know what they are talking about.
   / Why a Prodigy Brake Controller? #5
I have a prodigy in my 1-ton pulling 3 different trailers. Works great when switching between different weight trailers. Very easy to install, set-up and use.
   / Why a Prodigy Brake Controller? #6
I've got 3 brake controllers in 3 different tow vehicles, my favorite is the Jordan Ultima.
As for why to use a Prodigy, the only answer I can come up with is that it is popular, but that doesn't make it the best, it just makes it popular.
   / Why a Prodigy Brake Controller? #7
I agree 100%:D
I use the Jordan Ultima also. Absolutely fantastic!
Best Brake Controller
   / Why a Prodigy Brake Controller? #8
Buddy of mine had the Jordan and spent more time playing with the cables & setting it up than was worth for me. I have a prodigy in my GMC 3500 and a $49 Husky in my dump truck that works excellent.
   / Why a Prodigy Brake Controller? #9
The Prodigy also has a plug in harness in the back. This means that you can buy another $10.00? mounting bracket and you can transfer the one unit to your other vehicles. I use it to tow my 31' Jayco and my 14' utility trailer. All I do is set the boost for the Jayco and unboost it for the utility. Took me 20 min. to install with the factory harness that Ford gave me and that was because it took me about 15 minutes to find the cable under and behind the dash. Took me another 5 minutes to set the gain.
I would buy another one but I bought the mounting bracket for my other car so now I don't need another. :D
   / Why a Prodigy Brake Controller? #10
Prodigy
smooooooooooooooothhhhhhhh
2016 Ford Explorer...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2007 CHEVROLET BUCKET TRUCK (A52472)
2007 CHEVROLET...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
