bugstruck
Platinum Member
Had a stupid idea yesterday morning. Decided I should start my L3130 in neutral as the manual states. Usually start it in gear. Warmed it up good, went to put it in low range and it stuck and wouldn't engage like it usually does. Touched the treadle a few times with a little hand pressure on the range lever and it poped into low range, or so it seemed. Left the garage, started down my driveway about 90 feet and it popped into neutral. First I noticed the engine rpm's jumped up and in a flash it was off to the races. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Luckilly I was on my game and jumped the brakes pretty quick. That is an unnerving feeling on a really steep grade.
Is anyone else having issues with their range selector not staying engaged in the selected range? When mine dropped into low it was all the way back in the normal low range position. I eyeballed it. Never gave any indication of not being fully in. It's the first time that happened but in the wrong situtation it could get serious quick on my slopes.
My dash indicator/ range selector is out of calibration, so I can be in gear and reading neutral or reading neutral and in gear. Figured that range indicator calibration could wait till the 50 hr. service and I knew from the time I had 2 hours on it not to trust the dash indicator. I was sure it was a sensor adjustment which is probably reading off the range linkage position. Not exactly certain now what to think except to be on alert. BTW the range selector feels right going in and out and the label indictors by the lever are accurate.
I know the prudent thing would be to get it in for service early.
Any advice? /forums/images/graemlins/confused.gif
Lesson learned was that if you parked it in a selected non-neutral range, maybe it's best to leave it and start it there too; assuming you move right to slopes as I do. Another lesson was to always have the brake pedals tied together on slopes as I fortunately did. I overshot the left pedal when I panicked.
Side note: Those seemingly lousy brakes worked rather good when I went hard on them.
