Who makes the HST transmission in YOUR tractor?
   / Who makes the HST transmission in YOUR tractor? #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
I was doing maintenance on my Massey last night, part of which included removing the washable HST filter cartridges. There are two of them, identical filters, one sits apparently in the pump suction line, the other is found inside the bottom of the trans housing. these filters are separate from my spin on hydraulic filter, and I haven't seen a similar setup on the other two tractors that I owned, including a Kioti hydro and an LS hydro. So it got me thinking... Who makes the HST in my Massey? Who made the HST in my Kioti & LS? Iseki built my machine, but do they also build the trans? I tried googling it for an answer but didn't find anything defining the Iseki HST's. I did find an old post talking about tractor manufacturers purchasing components or the whole thing from HST manufacturers, including hydro gear, Kanzaki, Eaton, etc.
So ... does anyone know who builds the HST transmission and/or components in YOUR tractor?
   / Who makes the HST transmission in YOUR tractor? #2
That is a very good question and one I couldn't find much info on any tractor brand when searching in the 40HP range. I know my Mahindra has M&M cast into the housings of everything on mine. There was this tidbit from their corporate site:
Mahindra Gears and Transmissions
   / Who makes the HST transmission in YOUR tractor? #3
What a great post and interesting question.
   / Who makes the HST transmission in YOUR tractor? #4
The John Deere eHydro tranny is made by Saur Danfoss in their Ames, Iowa plant.
Thanks for that! Do you know which "product series" it's called? I tried checking into it, but they make quite a bit of stuff.
   / Who makes the HST transmission in YOUR tractor? #6
No Clue on my Branson or on the Kubota BX. My best guess would be that these trans-axles are made from components supplied by a major player like Eaton or Danfoss but the trans-axle assembly is built by a third party.
   / Who makes the HST transmission in YOUR tractor? #7
No I don't. I can ask them, I have a contact at Danfoss.
   / Who makes the HST transmission in YOUR tractor? #8
A wholly-owned subsidiary of Daedong d/b/a Kioti makes their own transmissions.
They sells them to others too.
Daedong Gear Company manufacturers gears, shafts, and transmissions.
New & Used Heavy Equipment Daedong - RitchieWiki
When your transmission shells, blame the Koreans. That said, General Motors named Daedong supplier of the year last year.
Daedong's automotive home page.
   / Who makes the HST transmission in YOUR tractor? #9
The Kioti DK series use Kanzaki (Yanmar subsidiary) HST transmissions. Here is supporting documentation to that fact:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=420847"/>
The HST transmission in my Yanmar LX is also built by Yanmar. The only document I can provide on that is this press release.
YANMAR | Yanmar America Announces New Lx HST Series Compact Utility Tractor
Interesting...That article claims that Yanmar is the only tractor manufacturer to build all of the major components of the tractor...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
1994 LUFKIN (A50854)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
71061 (A49346)
71061 (A49346)
