Who makes a thumb for the 110 TBL?
   / Who makes a thumb for the 110 TBL? #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Nothing against JD, but their 110 thumb requires the quick-change adapter plus the quick change style bucket.. I kinda prefer the pin on buckets. Maybe an aftermarket thumb will work with the pin on type? Anyone know?
thanks, scotty
   / Who makes a thumb for the 110 TBL? #2
Hi, I have a 110 and it came with all the plumbing and foot control for the deere hydraulic thumb (but without the thumb) I looked at the deere unit and really didn't like the way it was shaped and the thickness of the steel could have been better. I ended up purchasing a unit from northsaw Home
It was the first one they had ever sold for a 110, it's made for a John Deere 35 excavator I think and it hooked right up to the 110. It's way better than the deere thumb, much more heavy duty and shaped very nice to grab just about anything. If I remember correctly is was also quite a bit cheaper than the one deere has. I have the quick change bucket so I'm not sure if it would work with a pin on. Good luck!
   / Who makes a thumb for the 110 TBL? #3
Whenever I look at equipment these days - on line or on the lot - most stuff is goin' with quik-tach buckets.
And if you ever come across a sale or trade and there's a smaller (for rock's) or larger bucket; you'll be good to go!
The thumb on my 110 is from a JD track-hoe, too. I'd guess that the different buckets, thumbs, etc. for the smaller ZTS hoes would bolt right up to the 110. I haven't measured it -- but I'd bet my lunch money it's at least 3/4" stuff; maybe 7/8" like the boom lock.
If you tear up that hummer... you're not likely gonna be happy with the rest of the hoe, either.
AKfish
(APPROX 52) 2X6X16 PINE LUMBER (A54756)
(APPROX 52) 2X6X16...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
