Tollster
Veteran Member
I believe I have supplied power under my BX23 seat, and wish to run some fog lamps up to the rops ( got the alternator upgrade, whole good years back). I poked around here looking for older threads, but really could not weed through them all the aux light pictures.
Anyway, I believe the lead runs back under the dash to the only 20 amp fuse in the block, but not really sure? If that is indeed the case, I believe I can run off of that lead with a splice near the fuse block to the switch near the steering wheel, then up to the lamps with no relay?
I did find what I believe are the two leads, one Red/Black and the other Black with bullet connectors, thinking size 14 or 16, taped to the harness above the fuel tank?
The Hella fog lamps are pre-wired, but the directions show the use of the relay, and both diagrams show the fogs with switchable power going through the running lights, or the headlamps. Would this be the reason for a relay device?
Thank you,
Tol
Thank you,
Tol
