Who knew? Reading and actually following the directions does help
   / Who knew? Reading and actually following the directions does help #1
ustmd
Platinum Member
Manor, TX (outside of Austin)
Kioti CK27 HST
Since we moved to the sub-rural zone 14 years ago, every time I needed to change the blades on the riding lawn mower, I drove it up the small ramps I have, laid on my back and spent the next 2 hours cussing, complaining and injuring myself while getting the blades off.
This time, I actually read the direction that came with the ZTR. They told me to take the mower deck off :eek:. While skeptical at first, low and behold, I had the deck off, blades changed and deck reinstalled (and working :thumbsup:) within 30 minutes.
Maybe there is something to reading these directions.
   / Who knew? Reading and actually following the directions does help #2
That's sure one way to do it. Instructions do come in handy once in awhile. It's what I did for years with my Kubota GF1800 front-deck 4WD diesel, that's a bit heavier than the zero-turn mowers. This season I took a page from a local equipment dealer, who uses a chain hoist in their shop to lift the front end high enough to get under the deck comfortably. No ramps to get in the way of access. I put a chain under the deck's lift arms and used the loader on my larger tractor to do the same thing. Blocked up the deck once lifted, of course, for safety. Much easier for me than disconnecting the spring-loaded pins and the PTO shaft, flipping the deck on its back, then muscling and realigning everything back into position and hooking things back up. Whatever works. :thumbsup:
   / Who knew? Reading and actually following the directions does help #3
While I realize what I have is not the same mowing machine you guys are talking about, here is what I do to take the blades off of my little JD La135. I drive it into my basement shop, and I keep a hook eye bolt handy with washer and nut. Takes a couple of seconds to put that on, then lower the hook of my cheap chain fall's to the eye. The chain falls are attached to the floor joist over head. The chain falls make it extremely easy with practically no effort to raise the end of the mower way up off of the floor to get to the deck with the air impact. 1/2 a second later the blades are laying on the floor. I put them in the bench vise and and use the 4 1/2 inch angle grinder with a flap disk to sharpen them. The key takeaways of this dissertation is that the whole operation is a no strain no pain deal. The chain falls also came in handy when I put the head of my bandsaw on the stand. It was way more than this old man needed to be lifting, but chain falls make heavy lifting nearly effortless. And they are so cheap and easy.
   / Who knew? Reading and actually following the directions does help #4
All right... I'll admit (but only to you blokes) that I do read the directions & manuals.
But anywhere else and I will flatly DENY it!
   / Who knew? Reading and actually following the directions does help #5
I drive it up on the car ramps, and use my trusty impact wrench to remove the blades. I can remove the blades and put them back on in less than 10 minutes on my ztr. Sharpening takes a little longer. The front mount mowers are even easier. What are the instructions for anyway.
   / Who knew? Reading and actually following the directions does help #6
In most cases though, who can make heads or tails of the directions. By the time you get done bypassing the pages of insane safety warnings you hit the translation issue. I'm not going to say the owners manual for my Massey 1736 says to operate the machine at FULL THROTTLE for the first 50 hours. No, naw, just can't happen, impossible. Yea sure I must have dreamed it:shocked: :rolleyes: When I called the dealer and told him about it he heartily agreed it was absolutely stupid.
I do glance through them from time to time, especially if I have something in my hands unfamiliar but I always remain wary of foolish mistakes, translation errors and just plain non existent editing. Thank goodness for Youtube. :thumbsup: That's the best place to get real life procedures that actually work that I know of. Even some of those are poor but boy, some of those guys find some slick ways to get things done far better than the engineers.
   / Who knew? Reading and actually following the directions does help #7
If all else fails, read the instructions.
That is about the same as Winston Churchill's comment; Men and nations can be counted on to do the right thing, after exhausting all other resources.
   / Who knew? Reading and actually following the directions does help #8
You sharpen mower blades.....
Who Knew!
:laughing::laughing::laughing::laughing::laughing::laughing::laughing:
Later,
Dan
   / Who knew? Reading and actually following the directions does help #9
Its the taking something back apart 17 times unnecessarily that makes you an expert, not the words on written on paper.
Reading is for entertainment, it is sweat and blood that enlightenment is made of.
   / Who knew? Reading and actually following the directions does help #10
By the time you leaf through the instruction book to find what you need in ENGLISH the blades could be changed and the lawn mowed !
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
2019 International Bucket Truck (A55973)
2019 International...
Deere 335P (A53317)
Deere 335P (A53317)
DEUTZ MARATHON...
