Who has had wiring problems on their 2500 series??
   / Who has had wiring problems on their 2500 series?? #1
Ed_S
West Michigan
Cub 2523
As I posted before, I have been corresponding with Cub on the wiring issue. So far the answer has basically been "contact your dealer" which I had done previously, and "we are unaware of any feedback from dealers on this issue".
So, the question is ... who has a problem with the wiring? And who heard about it and took preventive measures before you actually had an issue?
Thanks,
Ed
   / Who has had wiring problems on their 2500 series?? #2
Yes, the left headlight wiring would have burned through on my 2544 if I had not wire-tied the harness out of the way of the exhaust heat shield. I still need to address this better. That really is a pitiful setup & I doubt you'd get a dealer to address it under warranty unless you let it burn up first.
G/luck
Joel
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
John Deere A Tractor (A50514)
John Deere A...
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
1 Oliver Front Weight (A50515)
1 Oliver Front...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
