who has gotten stuck worse pics!! lets see them
   / who has gotten stuck worse pics!! lets see them #1
NBstunter
Bronze Member
new brunswick canada
2006 kubota L2800
ill start off.
these are pics of 2 winters ago. just up the road from where we live the road has a huge slant and a 15 foot drop off after that that is so steep you cant even walk down it. well one icey day this is what happend. the front slid off the road and the back fallowed thank goodness there was 13 feet of snow to catch the tractor or it would have rolled so heres the L2800 sitting on 13 feet of powder.
oops dont know how i made 2 threads does a mod wanna delete one please?
   / who has gotten stuck worse pics!! lets see them #3
I have the R4's like you and found them to be really slick in wet snow. My tractor is sitting behind my lower bard right now stick in about 12" of fresh wet snow - it will not move, just spin - even in 4x4 with the Diff locked. It is a little slant but not one of our normal mountains. Looks l like chains are in order...
   / who has gotten stuck worse pics!! lets see them #4
This isn't the worse I have been stuck but one of the few pics I have of being stuck.
   / who has gotten stuck worse pics!! lets see them #5
   / who has gotten stuck worse pics!! lets see them #6
Ain't it suppose to be just a tad drier before attempting to plow:)
   / who has gotten stuck worse pics!! lets see them #7
This was a wet spot barely bigger then the tractor at the corner of the field. I had no trouble plowing as the furrow gave me solid ground for each pass and while discing I did fine through the entire field except for this spot and one spot on the other side where I had to unhook the disc, pull through and drag the disc through with a chain. This was the last field I turned over this spring and had already planted 20 acres of corn before I started it.
   / who has gotten stuck worse pics!! lets see them #8
I got stuck moving the 21-24" the last 2 days. In most cases, using the upcurl with the bucket fully down got me out.
If I had a driveway with lots of slope off to one side (my neighbor's is), I'd put lots of tall markers along the side of it. Of course, these wouldn't help if the front end starts to skid sideways. Only chains would help then.
It's tough moving snow with a loader and to keep from going off road too far. I can see that use of a snow blower isn't much help if you don't have the chains to hold your machine on the road.
Ralph
   / who has gotten stuck worse pics!! lets see them #9
Knock on wood but I have never been stuck moving snow. We had a 27" dump 3 years ago and 18" dump last year. We had a 36" dump 4 years back but I went out every 4 hours and keep ahead of it by plowing 8" or so at a time.
R1's go right though. My neighbors do have trouble with R4's and Turfs. They call me to dig them out.
Here are a couple pics of my rig and 280' drive.
Chris
   / who has gotten stuck worse pics!! lets see them #10
I have sure been stuck with R-1's, both with, and without chains, and in both snow, and really soft ground. There is the "best of times, and the worst of times" thing going on here, and in the worst of times tire type just doesn't matter at all. :D :D
(we used to break trail across drifted fields in the middle of winter, and again for maple sugaring time.) In the mud, it was bush hogging in a game preserve, and a lot of wet, and rough areas. Having the rotary cutter sitting on the ground behind you with the 3pt all the way up doesn't help. I remember one time I let the tires rotate just once after I sank, and when they came up full to the top with mud, I just shut the key off, and walked a couple of miles to get the dozer........ and it sure was needed. :D
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
