White Smoke Jinma 254
   / White Smoke Jinma 254 #1
Jinma284
Lady Lake, Fl.
Jinma 284
When I first start my tractor I get white smoke. What causes that? The smoke starts while cranking and stops almost as soon as the tractor starts.
   / White Smoke Jinma 254 #2
usually water in the fuel...
   / White Smoke Jinma 254 #3
White smoke is unburned fuel. You may have a slightly dribbling injector.
   / White Smoke Jinma 254 #4
White smoke can also mean a lean condition, check to make sure your fuel filter isn't getting plugged.
SR
   / White Smoke Jinma 254 #5
it is kind of normal when cranking to get white smoke, it is the cylinders just starting to fire but not quite enough heat, compression or some low fuel pressure till it all comes up and hits...
M
   / White Smoke Jinma 254 #7
If I don't plug in my tractor on a cold morning I get whitish/greyish smoke for a couple minutes but if I plug it in I get no smoke. This would lead me to believe that what STRIKER posted is the possible cause. I wouldn't worry about it.
   / White Smoke Jinma 254 #8
How does that work? Please explain
White smoke can mean a "leaned out" condition... A plugged or nearly plugged fuel filter will cause a leaned out condition... (not enough fuel getting through the filter)
It's another thing to check, NOT the only thing that can cause white smoke...
SR
   / White Smoke Jinma 254 #9
SR
I think what he meant was (and I am also curious as well) why a lean out condition results in a white smoke?
Also it is possible that a coolant leak via the head gasket could be causing this?
   / White Smoke Jinma 254 #10
There's a joke to be made there, but I won't make it.
Okay, yes I will.
They make pills to cure a "dribbling injector."
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
