Oil & Fuel White smoke during uphill pull
   / White smoke during uphill pull #1
netma1000
Cumming, GA
Kubota RTV500
New guy here. Anyone have an issue with the RTV blowing white smoke during heavy pulling uphill? Smoke starts to clear on level ground.
   / White smoke during uphill pull #2
Welcome to TBN
This is a gasoline engine?? Is it electronic fuel injection (efi) ??
   / White smoke during uphill pull #3
Black smoke = too much fuel, Blue smoke = oil and white smoke = antifreeze.
   / White smoke during uphill pull #4
Maybe not related, but I have run into that a couple times with my mule. The cause of all the smoke (when going uphill) was gas getting into the crankcase, and raising the oil level. On level ground everything is fine, but going up hill must change the crankcase level or something. All it takes on the mule is to change the oil. Then all is well until the next time. Seems to be a common problem with mules, especially when used for a lot of short trips when the engine doesn't get up to normal operating temperature.
I suppose the RTV is a diesel, but the same kind of deal may happen there, too.
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
(3) RYOBI POWERED BRUSHLESS PUSH MOWERS (A51244)
(3) RYOBI POWERED...
12' UTILITY SERVICE TRUCK BODY (A51244)
12' UTILITY...
Homemade Head Cart (A50514)
Homemade Head Cart...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
Terry 12ft Aluminum Jonboat (A50324)
Terry 12ft...
