White smoke. Any ideas?
   / White smoke. Any ideas? #1
Blue76
Yanmar 2500; kubota 3600
Here is a YouTube video of it running.
Just installed new pump and rebuilt injectors. Starts easily but that smoke...
YouTube
Greg
   / White smoke. Any ideas? #2
I didn't watch the video but white smoke can be an indicator of water or other contaminates in the fuel (coolant etc.)...white smokes means the fuel is not burning hot enough...
   / White smoke. Any ideas? #3
Is the engine surging on its own like that or are you revving it up and down?
   / White smoke. Any ideas? #4
Head gasket leak in one of the three cylinders - but what were the symptoms that drove the pump and injector replacement?
The tractor was abandoned on some property I bought. Been sitting somewhere around 6-8 years. Fuel pump was locked down and injectors gummed up.
Engine was surging on its on. I wasn’t doing anything.
It has clean fuel but I did put a diesel additive in it. Maybe too much for the small tank. May drain that out and refill with diesel only.
Greg
   / White smoke. Any ideas? #7
Unless you've completely drained the tank and changed the filters, it likely has water in the tank. Adding clean fuel will not remove the water problem.
I drained the tank. Washed it out. Rinsed it with diesel and let it dry. Installed new filter and new fuel lines.
Copied from my post at Hoye tractors forum...
Well. After our online Easter service. I decided to pull the exhaust manifold. Smoke was coming from the #2 cylinder pretty good. #1 was clean and #3 slight smoke. So... for kicks I swapped the injectors around... now smoke from #1 and #2 but #3 is clear. Seems one injector is working better than the others but it doesn’t clear up the #2 cylinder. #2 has unburnt fuel coming out of the exhaust port.
The pump is new from Hoye. I used factory shims. Wondering if it is shimmed correctly for this pump?
I like tinkering but I am ready to move on to other parts of the tractor.
Greg
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1981 FMC Link Belt Crane (A50120)
1981 FMC Link Belt...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
