white hydraulic oil
   / white hydraulic oil #1
crossbolt
salisbury,md.
ford 8n
just purchased my first ford 8n got it home and checked the hydraulic fluid it was white do they make something in white or does this mean water
   / white hydraulic oil #3
white means air or water entrainment.. in your case.. I'd guess water.
also.. it's important to realize that it is not 'hydraulic oil'.
it's a common sump machine, so your oil lubes the tranny, diffy, and hyds.
a UTF meeting the m2c134 spec is good.. or a mineral gear oil in the gl1 / gl3 level.. or a gl4 /5 80w90 gear oil that also carries a MT1 rating, and is yellow metal safe.
to dewater that sump I reccomend you drain it nearly all out ( holds 5g or so.. ) dump in 2 gallons of diesel, a quart of old F atf, and 4 pints of 90% rubbing alcohol, then take her for a drive around the pasture.. don't engage the pto.
then drain her fully.. remove the bottom bolt in the side cover where the dipstick is. add oil dill it dribbles from that hold. may be anywhere from 4.5 - 5 gallons depending on sump cleanliness.
also I suggest getting an I&T fo-4 service manual, master parts catalog and an owners manual..
soundguy
thank you very much i will try that and post the results
   / white hydraulic oil #5
post back if you hit any snags along the way..
   / white hydraulic oil #6
soundguy
And then run it until warm and drain and refill.
   / white hydraulic oil #7
WOW Soundguy! What a plethora of info you are! (no kidding) Awsome. When I read that I expected what rsewill said as well, get it done then drain and refill AGAIN. Where did you get that info from anywho? :confused: I am not contesting it, I want to know he history if there is any...
I have to ask, Why NOT run the PTO as well as other circuits with that mixture in it? Do we not want to purge those fluids out of hoses as well?
   / white hydraulic oil #8
At one time there was a white oil(mineral?) may still exist??. With that written I highly doubt yours is that type. As the others have said you more then likely have water mixed in. I would do what Soundguy suggested he is the mechanical buddha of the ford tractor :D
   / white hydraulic oil #9
Soundguy is correct. My 8n had a "Milk Shake" in it for hydraulic fluid. When you turn the PTO on it also turns the hydro pump on, you don't wont to run diesel in the the pump with all the dirt being flushed lose. You may need to drain the fluid 2 or 3 times to get the water out.
Philip.
i may have jumped the gun being color blind i didnot realize the fluid was actually yellow and a car mechanic i know told me this was a yellow hydraulic oil. when he felt the fluid he said that it was fine
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
