White blow by - possible causes/diagnosis?
   / White blow by - possible causes/diagnosis? #1
jsec
Murrysville, PA
Kubota B21
Hello,
Considering a Ford 2110 4 cyl desiel that I haven't seen yet. The owner says it has some white blow by. Right now I'm figuring its a coolant leak from either a blown head gasket or cracked block. I hope to make the 300 mile trip to see the tractor this weekend. I'm looking for advice on pinpointing the cause of the blow by while I'm there. Any suggestions?
   / White blow by - possible causes/diagnosis? #2
I'll assume this is from the breather not the stack?
Look for oil in water/water in oil. Any white smoke that doesn't clear up after warm up is deffinately a sign of a problem. I've seen a few 'white' smoke fuel issues however.
If someone has a 2110 or similar tractor I'm sure they will be along in a few to help you with some specifics.
Soundguy
   / White blow by - possible causes/diagnosis? #3
White smoke is usually unburned fuel. Blue smoke is usually from motor oil finding its way into the combustion chamber. Of course there can be many reasons for each.
   / White blow by - possible causes/diagnosis? #4
Yes.. BUT.. I would expect white smoke from unburned fuel from the stack.. if this white smoke is from the breather.. it is a different problem entirely..
Soundguy
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
3pt Cult. & Pipes (A50121)
3pt Cult. & Pipes...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
Rhino MD-84 (A50121)
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
