White 2-75
   / White 2-75 #1
Troyg65
White 2-75
With my 2-75 tractor I don't understand why the loader and 3 point does work together. I need to push a lever on side of transmission down to run loader and pull it back up to engage the 3 point hitch. The question is there a way into stop from shifting the lever up and down to change implements.
   / White 2-75 #2
I'm not familiar with the Iseki built tractors. From what I see in the parts lists I doubt anything would be available out there that would "bolt on" and do what you want. However, I do believe what you would like to have probably can be done if you're willing to do a little "creative engineering", and you have some welding/brazing skills. I think it would be an interesting project, not all that expensive, and make operating your tractor a lot less frustrating.
It would help if your loader valve was already power beyond capable.
   / White 2-75 #3
How many hoses connect to your loader valve. 6 or 7.
Do you have any rear remotes in the tractor and what is their behaviour relative to what you describe for the loader and 3 pt hitch.
Does your loader valve have a brand name and label on it.
What make and model info exists for your FEL.
Was the FEL installed when the tractor was purchased or did it come later in the tractor life?
My question regarding the number of hoses has to do with establishing if your loader valve has power beyond.
Dave M7040
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
