white 16.5
   / white 16.5 #1
stevend
is it possible to put a snowblower or a plow on white garden tractor it is 16.5 horsepower or would the tractor just get stuck and spin and could you drive it through 8 inches of snow with chains
any help would be appreciated thanks.
   / white 16.5 #2
Stevend,
Welcome to TBN!
I used a 42" snow blade on my White GT-105 (20HP) garden tractor for several years to clear snow. Even with wheel weights and tire chains, I found that plowing snow with this setup was tedious. Although it's better than using a shovel, I found that the tractor would constantly drift off-course and get stuck. If the ground is flat, 8" of snow would be close to the maximum ability of this setup. (I also quickly learned that if you are not able to remove all the snow in one pass, the tractor would quickly lose traction). Here in Virginia, it doesn't snow very often, so the setup was "adequate" for my needs. If you live in a region where 8" snowfalls occur on a regular basis I would recommend using a standalone snowblower instead.
My opinion is you could "get by" with using the plow on your garden tractor if that is your only option, but you will be able to clear the snow much faster (1 hour vs 3 hour for me) with a standalone snowblower.
I have never used a tractor-mounted snowblower, but I would guess that it would overcome the traction and lack of power problems that I experienced with the plow.
Please let me know if you have any more questions, and once again, welcome to TBN!
Charles P
   / white 16.5 #3
Which transaxle does it have? If its the MTD transmatic, don't waste your $. You'll just burn up belts and variators.
Joel
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
Aluminum Boat Top (A53117)
Aluminum Boat Top...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
UNUSED Single Stall Portable Restroom (A53117)
UNUSED Single...
