whining update
   / whining update #1
djp1218
chichester nh
mahindra 2816 hst tlb
just an up date to my mahindra 2816 that seemed to whine a little extra and slow return on the hydro pedal. Stopped by the dealer today and started the same machine it sounded about the same but the pedal came back alot faster they are ordering the spring on the shaft that they say sometimes goes bad from sitting.they also gave me a gallon oy fluid
   / whining update
also they told me that some people use a thinner oil and it helps a lot was wondering if anyone has done that and if so did it work?
   / whining update #3
glade they gave you the fluid and i hope the new spring fixes the return problem. i just find hit hard to belive that just sitting there for a year caused that spring to go bad. i think once you get the proper amout of fluid in the system will help the return problem as well.
   / whining update
its a 2010 so a cpl yrs atleast i thought the same thing and the spring isnt exposed either but they didnt seem suprised if nothing else its a good start
   / whining update #5
Sounds like that might be a design flaw with a substandard spring that stretches if they have had a few complaints. GOOD Springs shouldn't loose their tension unless overstretched or heated and certainly not setting in neutral position for years and years. It could be that they put too weak of a spring on at the factory and are replacing them only when warranted or someone complains. Check spring coil diameter and wire diameter of the new one compared to the old one when you get it and see if they are the same.
   / whining update #6
Did you try a little penetrant on the linkage and where the shaft goes inside of the side of the transmission housing? Lubricating the linkages is important and may just solve your problem.
The whining on the hydro is some what normal on that model, and it doesn't hurt a thing. The hydrostat on that model, almost never gives any problems.
   / whining update
have you ever heard that using synthetic oil makes it alot quiter?
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
2002 Freightliner FL70 Sweeper Truck (NOT RUNNING)(TITLE) (A50774)
2002 Freightliner...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
