Whine during cylinder operation
   / Whine during cylinder operation #1
endless tracks
LS XR3037H
I have. mini excavator (Volvo EC35) that had a slight whine when you initiated a command on the tracks or any cylinder. It seemed to go away once the oil warmed and I revved it up a bit. But now, warmer weather is here and it getting worse. I don't think cold oil is a problem anymore. The oil level is proper and it does not whine unless I move something. It's much louder if I move something quick. Thinking plugged filter but the oil looks pretty good. Cylinder or track speed is normal, just loud. Any ideas?
   / Whine during cylinder operation #2
I believe that model has a variable volume load sense pump so pump only moves oil when a function is commanded to move.
If you feather the controls so function barely moves is the sound present and does it change when movement is faster? If yes is it a whine or growling noise?
Whine could be normal while growling would indicate a potential air leak or restriction in pump inlet / suction line.
   / Whine during cylinder operation #3
Any bubbles or “froth” in the hydraulic oil? I had a suction side leak on my splitter that caused a whining, ended up being the air whipped into the hydraulic oil from the leak.
MISC CABINET PARTS (A54757)
MISC CABINET PARTS...
1840 (A51248)
1840 (A51248)
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
