Which would you choose
   / Which would you choose #1
4tillingdirt
nc
N/A
I know this about TYM, but I want input from everyone about which size you would choose - just ignore the brand. The T474 and the T494 have the same engine and HP, but the 494 is a larger chassis tractor. Despite what Hank says about the lifting capacity, the 494 does have a greater lift capacity. I was thinking 494 because of the being able to use that HP better due to the 494 being about 600 lbs. heavier. heavier. Seems like the HP would go to waste on the 474. There is about 2K price difference.
The TYM TRACTOR! TYM T474 /TYM T494 /TYM T574 /TYM T654 - YouTube
   / Which would you choose #2
Weight is your friend. Go with the heavier unit.
   / Which would you choose #3
I don't know what you plan to do with the tractor but generally the larger tractor can do more work. The only exception I can think of would be if you want a belly mower and it's an option on the smaller tractor but not the larger. You have to consider your specific needs.
   / Which would you choose #4
I didn't look into dimensions between the two machines, but it would not be hard to add 600lbs to the lighter one... For a lot less than $2k. The other factors that I would consider are width, and ground clearance.
I went with a larger tractor than I really needed for the weight and width, which generally increase in larger chassis machines.
   / Which would you choose #5
I would go with the 494. Heavier chassis, more ground clearance, better lift capacities on FEL and 3 pt.
No brainer.
Get the FEL, and the cab, and the hst trans.
It's fun spending other peoples money.
The 494 is a little over 9 inches wider, but it also has larger tires so some of the width increases comes from that.
   / Which would you choose #7
Just get the one YOU want sometimes bigger is not always better .....
I know what you mean - just having a hard time deciding. I can think reasons for and against both tractors - lol.
   / Which would you choose #9
Take them for a test ride I went with the l47 TLB because it was in the middle....not to small not to big... Take your time you don't want two tractors do you....:rolleyes:
   / Which would you choose #10
Depends on what you plan to use the tractor for... For me, buying less HP has not been a problem, I used my tractor for fun. Saved money to spend on every implement imaginable. Implements = work you can get done. Buying used means saving even more - Plus learning to weld to fix everything has been great.
BUT... if I was to try and make money for a business. Less HP would be somewhat limited.
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2017 Ford Expedition SUV (A50324)
2017 Ford...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
