handirifle
Veteran Member
I am considering, no major decisions or commitments made as yet, buying a diesel 3/4T to pull my 5th wheel trailer with. It's a light weight model (5200lb dry) meant for 1/2T trucks and that is what I currently tow it with. I use my 2006 Tundra, w 4.7L, rated to tow 7,000. The truck is my regular driver. I didn't say daily, on purpose cause sometime I don't start it for 3-4 days in a row. We are retired and if the wife goes along, we take her car, unless we need to haul something big. While towing this trailer I get an avg of 9 mpg on reg gas. About 17-18 freeway.
This is an old picture of the combo (when I first got it), and I have since had the trailer raised 3" and adjusted the pin to allow the trailer to tow level.
Overall I am pleased with the setup, but the truck has some limitations. The brakes could be better, and aftermarket products are either sky high prices or non existant. Ao I was considering an older (cause no way can I afford new) and would like to basically sell mine and buy one with the same cash, which I estimate to be about $16-17K.
In the Ford line it would have to at least have the 7.3 Powerstroke, and not the older 7.3. I have read too much negative about the older engine. In the GM line, I believe it's the 6.5 Duramax? For Dodge obviously the Cummins I6, but I know there are a lot of versions and not sure if there are any I should avoid.
My needs are not huge, and I am considering the upgrade in power cause a lot of rental companies are requiring 3/4T min. That's not a big reason, but it is one. I would like to have considerably more grunt for pulling long grade with the 5th wheel, and better brakes.
I do not see us ever getting a bigger trailer, smaller if anything.
Are there any years of each brand that I should avoid? Bad trannies, etc? I know the 6.0L Ford were problematic, but also understand there are SUPPOSED to be after market cures. I'd rather not get one I HAD to sink $$ into to make it reliable. I bought my Tundra with 17K on it and it have never needed to go to the shop since i bought it, except for sched maint.
Not wishing ANY "my brand is better" comments, just honest opinions. I suppose I would be looking at trucks with 100,000 + on them as well.
Any well known issues mentioned are greatly appreciated. Opinions of the whole idea appreciated as well.
