which tractor for forklift?
   / which tractor for forklift? #1
klog53
Nauvoo,Ill.
jd5520n, kubotal3800, yanmar
I want to mount a forklift mast on one of my jd tractors. The mast has one hydraulic line. I have a jd870 with power beyond and a jd1070 with joystick and plumbing for a fel. The mast will be 3pt. Which tractor would be the easiest to plumb and how? Any ideas appreciated.
   / which tractor for forklift? #2
Welcome to TBN:)
I vote the 1070. The 870 with PB would need a valve plumbed to operate the mast since the PB lines flow oil whenever the tractor is running. The 1070 already has the valve, you would just need to run a hose from the front QD to the mast cylinder.
Since the cylinder is SA (single acting) and has only one hose, the tractor will go into "relief" while the mast is lowering, but that will not be a problem.
   / which tractor for forklift? #3
Hydraulics aside, you want to mount it on the 1070 for capacity and stability.
Went with the 1070 because i'm cheap. Took awile to find the right port but works great. The 870 would have been easier to manuever in tight spots but not worth the added cost. Thanks for the replies
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
