jenkinsph
Super Star Member
Working for others can make it harder to decide which implements will fit the best. If the cost is low enough I would consider buying both disks, after using them you should be able to sell the one you don't need with no money lost. You might find both handy to have too.
I have to transport my equipment around Ruidoso NM on a trailer all the time. If and when I buy a disk it will be an 8' pull type with 22" notched blades, just easier to manage. Most of the jobs I work are small and range from 3 to 10 acres fields so it doesn't take long to do and I am moving equipment again. When you are moving the equipment longer distances as you have indicated it becomes more important to have the right stuff. The right drill or power till seeder might be a better fit for you as I have found that the truck and trailer will often use more fuel than the tractor for small jobs.
