Which size tractor--help, please
   / Which size tractor--help, please #1
Dakota Joe
Berkshire County, Massachusetts
Kubota L2350DT; Gator XUV 825i S4
Please help me size my new tractor!
I am a noob, alas, but have greatly enjoyed learning from you all over the past months reading your very interesting posts and advice to others.
We have 165 acres in Western Massachusetts, just under the Appalachian Trail, shared by three families. About 50 acres of meadows, 15 acres of scrub/border land, 60 acres of forest, 10 acres for houses, 30 acres runs up the mountain to the Trail and is too steep for a tractor.
The house lawns get cut with a Cheetah.
For the last 25 years, the walking trails (3 miles around the meadows, 8-9 feet wide, which get cut with a finish mower once a week during growing season) and forest trails (2 miles, 6-8 feet wide, bush hogged a few times a year) have been maintained by a caretaker with a 1995 Kubota L2350 pulling a 5 foot bush hog and a bush hog finish mower. The 60 acres of meadows have been cut by local farmers with their big tractors--but we envision taking back care of those in a few years and just bush hogging them 1-2 time a year, as currently happens with scrub/border land.
I don't expect a ton of FEL work, but in addition to the mowing above, would expect applications to be:
Moving stones (not too huge)
Maintain 1/4 mile of gravel driveway, every two or three years
Moving piles of brush
Moving downed trees from lawns and from walking trails
Regrading grass and dirt trails to deal with impaction, erosion, wet areas, etc
Possibly plowing drives in winter, but the snow amount is dropping fast as things warm
As things warm, the precipitation is picking up and the trees are growing mossier and the soil is damp more often. The L2350 has turf tires and I think I would stick with those. (The L2350 has been great, but in retrospect was probably too small this whole time.)
I would like to buy one tractor that can last the next 30 years. I don't have much experience driving or operating one, but as I move closer to retirement I hope to take that over.
On the one hand, I'd like it not to tear up or compact the trails too bad given how things can be more damp here now, and I'd like it to work in the forest trails (through which the Kubota L2350 just fits with a 5 foot bush hog).
On the other hand, I only want to buy one tractor and to have it be sufficiently powered and not to have any regrets.
I expect we'll probably get a Kubota again.
What size do you think I should get?
Thank you so much.
   / Which size tractor--help, please #2
Kubota L2350
1991 - 1998 L50 Series
Compact Utility tractor
Manufacturer: Kubota
Variants:
L2350F: 2WD
L2350DT: 4WD
Kubota L2350 Engine:
Kubota 1.1L 3-cyl diesel
Kubota L2350 Power:
Engine (gross): 25 hp [18.6 kW]
PTO (claimed): 20.5 hp [15.3 kW]
Capacity:
Fuel: 7.7 gal [29.1 L]
Hydraulic system: 7.4 gal [28.0 L]
3-Point Hitch:
Rear Type: I
Rear lift: 1433 lbs [650 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540
Dimensions & Tires:
Wheelbase: 61.2 inches [155 cm]
Weight: 2200 lbs [997 kg]
Front tire: 7-14
4WD Rear tire: 11.2-24
full dimensions and tires ...
Kubota L2350 attachments:
front-end loader
L2350 Serial Numbers:
Location: Serial number plate on the left side of the L2350 tractor frame, above the front axle.
photo of L2350 serial number
1991: unknown
1992: 51460 (L2350DT)
1993: 52900 (L2350DT)
1994: 55760 (L2350DT)
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 7.4 gal [28.0 L]
Pump flow: 4.4 gpm [16.7 lpm]
Electrical:
Ground: negative
Battery:
Number: 1
Volts: 12
Page information:
Last update: December 28, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
   / Which size tractor--help, please #3
That's what he has now and want's a bigger tractor.......
   / Which size tractor--help, please #4
One increment more capable than your Kubota L2350 is the Kubota L2501. However L2501 can barely manage a 5' Rotary Cutter with 25-horsepower.
Moving stones (not too huge) WHAT WEIGHT??
TREES CAN BE CUT INTO MANAGEABLE PIECES BUT NOT STONES.
Possibly plowing drives in winter, but the snow amount is dropping fast as things warm.
L2501 can handle above tasks.
A Kubota 'Grand L' L3560 is a little bigger but 3,700 pounds bare tractor weight + 37-horsepower. An L3560 can handle these tasks with a safe margin. Most of your applications call for tractor weight. The exception is mowing, where horsepower is as important as tractor weight. Grand L 'de luxe' models are much easier to grow old with than economy tractors. I am growing old with an L3560 myself.
VIDEO: Kubota Standard L Series VS. Grand L Series - YouTube
To mow 60 acres, even once or twice per year, I would want a 12' wide or 15' wide twin spindle rotary cutter behind a cab equipped tractor with ~~100+ horsepower.
Calculate how much time you are willing to spend mowing 60 acres:
Mowing Calcuator | How many acres can I mow in an hour
Kubota L2501
2014 - Standard L Series
Series next: Kubota L3301/L3901
Kubota L2501 Engine:
Kubota 1.6L 3-cyl diesel
Kubota L2501 Power:
Engine (gross): 24.8 hp [18.5 kW]
Engine (net): 23.9 hp [17.8 kW]
Gear PTO (claimed): 20.5 hp [15.3 kW]
Hydro PTO (claimed): 19 hp [14.2 kW]
Capacity:
Fuel: 10 gal [37.9 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 1918 lbs [870 kg]
Rear lift (at 24"/610mm): 1389 lbs [630 kg]
Rear PTO: transmission*
live*
Clutch: overrunning dry disc
Rear RPM: 540 (1.375)
Dimensions:
Wheelbase: 63.3 inches [160 cm]
Weight: 2425 to 2623 pounds
Kubota L2501 attachments:
Loader type: Kubota LA525
Height (to pin): 94.3 inches [239 cm]
Lift to full height (at pin): 1131 lbs [513 kg]
Lift to 1.5m (at pin): 1490 lbs [675 kg]
Lift to 1.5m (at 500mm): 1182 lbs [536 kg]
Mechanical:
Chassis: 4x2 2WD*
4x4 MFWD 4WD
Steering: power
Brakes: mechanical wet disc
Cab: Two-post folding ROPS.
Hydraulics:
Type: open center
Pressure: 2205 psi [152.0 bar]
Pump flow: 5.15 gpm [19.5 lpm]
Steering flow: 3.13 gpm [11.8 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Charging volts: 12
Battery:
Number: 1
Cold-cranking amps: 490
Volts: 12
Page information:
Last update: January 2, 2019
Copyright: Copyright 2019 TractorData LLC
   / Which size tractor--help, please #5
I’m of the philosophy that the greater the power, the more utility you can receive from the machine. My recommendation would be to go with the largest you can afford, transport, and fit into tight areas around the tract. Do you already have implements?
Equipment is a big ticket item that can sink a ship. Ensure that you are cognizant of the storage, maintenance, and repair burdens of owning equipment.
I’m sure specific recommendations can be applied to your brand preference by experienced users.
   / Which size tractor--help, please #6
Don't get stuck on tractors.
I thought like you that a tractor was the way to go but after I sold my tractor. Because it was underpowered to do the things I needed I looked at a skid steer.
I never plowed fields with my tractor I mainly needed for things like you said. Clearing, lifting, etc.
I went with a CAT 289 and it was amazing. With my tractor using the grappler by the time I put the heavy grappler on I wasn't able to lift any debris. With the skid steer, I was able to lift as much as I could crush in the grappler.
Because I was able to change attachments from inside the cab, I would often switch several attachments in a day. From the bucket to the grappler, to the lifting arm, the large turkey litter bucket, the tree spade, rock bucket, forks, road grader attachment, and yes I even had a backhoe attachment made by CAT.
Since I never needed any three-point hitch attachments it was perfect. Being a track loader I was able to spin on a dime when I got in tights spots, unlike the tractor.
All in all, it was the Victorinox of tractors for me. With the grapple, I was able to grab large rocks and place them wherever I wanted.
Anyway give it a thought and take like a Kubota track skid steer for a test ride.
   / Which size tractor--help, please #7
Welcome to TBN. If you need to stay at 5' wide to maintain the forest trails, I would looks at a Kubota L series like the L3901. Higher HP so you can mow with a bigger mower, good weight for stability and pulling power and still under 5' width. I would also consider other brands like Kioti or LS if you have local dealer support. I would look in the 35 hp range.
   / Which size tractor--help, please #8
Are the areas you mow and the trails flat or hilly? Do you have any brand preferences? Can you post any pics of the property?
   / Which size tractor--help, please #10
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Neophyte tractor operators are often intimidated by instability of tractors with small front wheels and large rear wheels, therefore frequently purchase tractors too light, too small for long term satisfaction. ((Tractors seem to shrink after about twenty hours of operating experience.))
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres.
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
JLG MAN LIFT (A52472)
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
