Tiller Which size tiller?
   / Which size tiller? #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I have a John Deere 4200 with hydro transmission (approximately 28 overall HP). My property has a fair amount of clay (as does the entire county here). Would a tiller in the neighborhood of a 60" width be the best way for me to go?
   / Which size tiller? #2
Gary,
The Land Pride Tiller (RTA20 series) is a medium duty tiller that is rated for tractors 23-40 HP and may be worth looking at. Landpride states that horsepower range can handle up to a 72 inch tiller.
Phil
   / Which size tiller? #3
Just right, Gary. Or if you find a deal on a 55", that should cover your tracks also, if your wheels are not reversed. BTW, you can save a lot of wear and tear on a tiller by scarifying first with the teeth on the box scraper.
   / Which size tiller? #4
I run a 60" KK tiller on my 4100. I can't go full depth on virgin soil on the first pass without lugging, but it tears up the soil so darn quick that I want to go over it 3 times just to get the seat time in. I have some pretty hard clay myself. The first year with the tiller was kind of tough, but I have a feeling the garden will be nicer to it this year.
I would expect you'd be fine. I would have went smaller, but couldn't justify spending more for less since a KK 48" costs more than a 60".
   / Which size tiller? #5
Gary,
With the presence of clay you best stay with the 55-60" tillers. The HST feature on your tractor will allow you to go slow enough for the proper operating speed to maximize your HP.
   / Which size tiller? #6
I have an L3010 (32 HP), and a 48" tiller. Most tillers can be side shifted to you can be sure you can cover one wheel track, so you don't need a big one to cover your tracks. Its unbelievable how much tilling you can do and how fast you can do it with one of these, so you usually don't have to get a big one for productivity. What can take days with a walk behind takes an hour with a 3pt. /forums/images/graemlins/smile.gif
Clay will be hard on the tractor and the bigger the tiller the bigger the load. I'm happy with my 48 incher, you might consider getting a smaller one.
   / Which size tiller? #7
I ran a 74" Bushhog tiller w/ L2900 Kubota.
Worked good even in rocky clay sod (my yard).
Works even better w/ NH TC35D .
   / Which size tiller? #8
I run a 60" King Kutter II gear drive tiller on my 27 hp 7272 Cub Cadet tractor. I have tilled approximately 12 acres in the year that I have had it and couldn't be happier.
Jerry
   / Which size tiller? #9
Gary,
I just bought a First Choice 74" tiller for use behind my JD4710 (40+ hp on the PTO with my hydro tranny). I have heavy clay on my property - and spent about 8 hours last weekend tilling 5 acres. I had the tiller set for full depth - so the tractor got a good workout. I would not go any higher than 60". Keep an eye on your temp gauge - a few times I had to disengage the PTO and let things cool down for a bit...
Get a slip clutch!
I am really happy with my First Choice tiller.
BTW - I had many conversations with Mark at CCM and - while I didn't buy tiller from him - he was super helpful. In fact - he wouldn't let me buy the "wrong tiller"
Bill
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
New Wolverine Dingo Bucket Broom (A50774)
New Wolverine...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
2019 Freightliner M2 106 18ft Landscape Dump Truck (A50323)
2019 Freightliner...
