Which Semi-mount plow for my Ford 7710 II FWA?
   / Which Semi-mount plow for my Ford 7710 II FWA? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I want a moldboard plow to pull behind my Ford 7710 II with FWA. From my research, it seems that a 4 bottom semi-mount plow might be a good choice. Also, from my research, it seems that different brands of plows utilize different types of draft control (3 pt arms vs top link). In your opinion, what would be the OPTIMAL plow (brand and model) for my tractor? Thanks!
   / Which Semi-mount plow for my Ford 7710 II FWA? #2
I assume "semi-mount" moldboard is 3 pth mount. But on 3 pth the draft control is in the tractor not the implement. I have been told some tractors use the 3 arm to control the draft. No idea how they do it.
   / Which Semi-mount plow for my Ford 7710 II FWA? #3
Draft control sensing is determined by the tractor design, not the plow. Your 7710 uses top link sensing, so a semi mount plow will not send any draft signal to the hitch valve. I would look for an IH or CaseIH plow, or a plow built by White and sold as a White, Ford, or Case. All would be good choices if not worn out or abused.
   / Which Semi-mount plow for my Ford 7710 II FWA? #4
Kvernland is also a good brand of plow. Soil type & bottom width determines the size of plow you can pull. I would guess that 4 - 16's is correct but in some areas you could possibly pull 5 or only 3.
   / Which Semi-mount plow for my Ford 7710 II FWA? #5
I have a 3 bottom semi mount. I just set the depth wheel and let it go. the draft doesnt work with only the 2 arms in use draft is on the top link
   / Which Semi-mount plow for my Ford 7710 II FWA? #6
Correct me if i'm wrong but didn't companies make converters to move the draft sensing to the top link for semi mount plows?
   / Which Semi-mount plow for my Ford 7710 II FWA? #7
Any brand plow is ok!!!---Just stay away from Allis plows!!--- can't get shares for them! thanks; sonny580
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
Duetz Power Unit (A50120)
Duetz Power Unit...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
