rancar
Veteran Member
- Joined
- Jan 26, 2002
- Messages
- 1,719
- Location
- Cambridge, New York
- Tractor
- JD425 lawn tractor; JD4710 CUT; JD JX75 Walk Behind
OK....here's a question for you machinists and hardware techies .....
I'm rehabbing an old carryall for my JD4710 tractor. I recently had to have new lower lift pins custom made due to the old pin's incompatibility with the ball and socket ends on the lower draft links. The lower lift pins are housed in a bracket assembly that is bolted onto the carryall's frame. Two bolts fasten each bracket assembly to the frame's sides...four bolts total.
The old Hex bolts were 1/2" by 3 1/2". I intend to retain the 1/2" diameter since I don't have the tools to re-drill larger holes in the carryall's frame. The lift capacity on a JD 4710 3PH is 2,500lbs but I don't anticipate carrying anything greater than about 1,500 lbs (new custom made pins were threaded for this load capacity). I'll be using the carryall primarily to haul logs out of the woods and fieldstone out of the hedgerows.
Now, the question:
What Hex bolt SAE grade is recommended for this kind of assembly? I can't bring myself to use the fragile SAE 1 grade products I see in Home Depot due to safety concerns. I don't want to see these bolts snapping off under heavy loads. I've thought SAE 5 grade would be sufficient. SAE 8 grade sounds like overkill and are quite expensive possibly requiring me to buy a whole box of these which I don't need.
Anyone have any thoughts on this issue? Thanks for any input.
....Bob
Now, the question:
....Bob
