Rotary Cutter Which rotary cutter?
   / Which rotary cutter? #1
STx
Veteran Member
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I have a New Holland TC40DA, 33HP at the PTO. I currently have a Rhino TW72 that is probably 15+ years old, it's built like a tank but had some hub damage and needs some work done to get it back into working order. I think I'm going to repair it and just leave it at my property so I don't have to trailer it and the tractor back and forth. I have some field and pasture mowing jobs here in town that I need a cutter for as well so I'm considering buying a new one to use for those jobs and am looking at the following -
  • Rhino 172
  • Land Pride RCR1872
  • Modern Ag Super Sunshine 6'
Of those 3 mowers, which do you guys think is the best and why? All are within about $400 of each other so price isn't really a consideration.
Thanks for the input!
   / Which rotary cutter? #2
Almost, almost all R/Cs sold new today have gearboxes, shafts and blades from two suppliers in China. These suppliers sell multiple grades for multiple price points. A zillion of these components can be packed in one shipping container from China to US West, East or Gulf ports, then on to implement manufacturers in the South.
This includes my Land Pride RCF 2060 @ $1,600 without sales tax, purchased January 2014.
Look for gearbox HP rating, you want twice your tractor PTO output. A heavy deck is important, which is reflected in total weight.
   / Which rotary cutter? #4
5 Things I think are most important when looking at a cutter.
.......................................Landpride.....................Rhino.....................Modern
1. Gearbox Rating................???.............................65HP.......................65HP
2. Cut Capacity....................2"..............................1.5".........................2.5"
3. Blade Tip Speed..............15000.........................15000......................15000
4. Deck Thickness................10ga............................10ga.......................3/16 (7ga)
5. Weight............................737..............................785........................865
I would assume the landpride also has a 65hp gearbox. The Modern is the heavier built unit with a heavier deck, probably why its rated to cut a bit thicker stuff.
But they are all pretty close And I doubt you would notice any difference in cut, or what they can and cannot do in the real world. You mentioned some "jobs" you are doing. What are these "jobs"? Are you mowing commercially? Or mowing alot. Cause if so, I would step up one notch and get something with ~100HP gearbox and 3-4" cut capacity. Those would weigh in around 1000# but handle alot more abuse if mowing unknown territory and hit crap.
Also look at a bushhog BH16. Specs mirror the 3 you listed. But alot of people speak very highly of the bushhog brand cutters. Myself included. I have a 30+ year old 306 cutter that I use commercially and give it a ton of abuse. Still going strong.
   / Which rotary cutter? #5
I can't comment on the other brands since I've never owned or used them. I have a 6 ft landpride rotary cutter and it's been pretty good. I have a 35 hp Century 4x4 tractor with 30 hp at the PTO and I feel it's maxed out with the six foot cutter. It can pick it up and power it through whatever I drive through, but I had to add weight to the front end since I don't have a FEL and there where times when I was too heavy in the rear and there wasn't enough weight on the front to steer.
The only real issue that I had with mine is the rear wheel metal that goes down on either side of the wheel wasn't very strong and it bent fairly quickly. I replaced it with a new one and it bent the same the first time out just turning. I've since replaced it with a home made bracket that is much heavier and stronger that has lasted me a decade without any more issues.
The most important reason to pick a brand is support. I buy parts online for mine at Messicks and I go to the local Kubota dealer who is pretty quick at ordering them. I think Messicks is faster. As for price, I've never compared who is better, I just tend to go with whatever one fits my needs at the time. New blades are just over $40 each at Messicks.
Eddie
Yes, they're commercial mowing jobs but primarily just large fields with grassy plants, not much actual brush. The mowing I do on my own property is a lot more abusive than the paying jobs. On my own, I'm cutting mesquite, acacia, rocky areas and occasionally find a hidden cinder block, which is why I think I want to dedicate the TW72 to that work and buy something else for here. The TW72 can take the abuse and I didn't give much money for it. It would work fine for the paying jobs also, I just get tired of towing the tractor and cutter 270 miles each way and with the cutter on the trailer, I really don't have room for any other implements.
Knowing how I am though, at some point I'll probably end up with 2 of everything and only move the tractor back and forth.
   / Which rotary cutter? #7
So, are the Woods Brush Bulls gear boxes made in China??? Last I looked they were still coming out of Italy.
The Woods Brush Bull WILL be my next Rotary cutter!
SR
   / Which rotary cutter? #8
The last time I looked before buying my Land Pride RCF 2060, perhaps four years ago, gearboxes were from Italy too. No longer. Every R/C I checked at at my Kubota dealer had Made In China on the gearbox, somewhere.
PTO on RCF 2060 remains from Italy.
   / Which rotary cutter? #9
I have several different brand of rotary cutters. I think any of those would do you a good job. I agree with Eddie, look at the support you will have for each mower. I would also consider the price for parts. At some point you will need new blades. I like my Rhino & Bushhog cutters, but parts are expensive.
I'm going to go take a look at the cutters today but I think I'm going to buy the Modern. The parts to fix the TW72 are on the way, it actually broke the unformed bar that the blade was attached to so I'm replacing that and the belly pan. With the way I abuse it in South Texas, the blades stay almost flat so it doesn't cut grass worth a dang but it'll eat brush and small trees like they're nothing.
Thanks for the input, guys!
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
5-Bottom Plow (A52128)
2024 CATERPILLAR 305CR EXCAVATOR (A51242)
2024 CATERPILLAR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
